Where should my horn relay be? - Ford Truck Enthusiasts Forums
Old 09-10-2010, 09:10 PM
bloodspoint bloodspoint is offline
bloodspoint is starting off with a positive reputation.
Someone at some point decided my '79 F-250 4x4 (351M, NP435, NP205) didn't need several niceties like windshield washer and horn. Now the WS washer, I can figure out - wiring is still there, and the holes are still on the inner fender.
The horn is another matter. I have a horn mounted on the radiator support, and no wiring leading anywhere near it. I gather a yellow wire with a green stripe should appear out of one of the harnesses somewhere, go to a horn relay, and then to the horn, but I don't have a horn relay either, from what I can tell.
Can someone with a horn either give me a good description of where the relay goes, or better yet, post a pic of where it sits?
Thanks,
Sean
'79 F-250 4x4, 351M, NP435, NP205, Cincinnati, OH
Old 09-10-2010, 09:28 PM
Bullitt390's Avatar
Bullitt390 Bullitt390 is offline
Certified Thread Hijacker
Bullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant future
Should be mounted just up from the starter solenoid on the passenger inner fender.
Josh
Old 09-10-2010, 10:37 PM
TexasTrash's Avatar
TexasTrash TexasTrash is offline
TexasTrash is starting off with a positive reputation.
I posted this a few days ago, someone said the first pic is the horn relay.
http://www.ford-trucks.com/forums/99...ification.html
Old 09-10-2010, 10:46 PM
steponit steponit is offline
steponit is gaining momentum as a positive member of FTE.
Do you have speed control ?
If so the horn relay is mounted to the dash support bracket behind the instrument cluster
77 was the last year for horn relays under the hood.
Old 09-10-2010, 10:49 PM
Cool, thanks! That also tells me what to look for in the wiring to hook up to it. Why you'd remove that - or the washer reservoir - I have no idea.
Old 09-10-2010, 10:50 PM
Hmm. Nope, no speed control. I wonder if the relay is up under the dash, in which case, I just need to figure out how to get some wires from it to the horn.
Old 09-11-2010, 08:04 AM
Blown 331's Avatar
Blown 331 Blown 331 is offline
Blown 331 is gaining momentum as a positive member of FTE.
Quote:
Texascrash posted a picture of the relay above and its right where Bullit390 said it was- on the inner fender.
Old 09-11-2010, 08:37 AM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
The OP has a 1979 F250 without Speed Control.
1978/79 F100/350's, Bronco's & Econolines without Speed Control do not have a horn relay.
1978/79: With Speed Control, the horn relay mounts to the Speed Control's amplifier which is mounted under the dash adjacent to the fuse box.
D6TZ13853A (replaced D3TZ13853A) .. Horn Relay (Motorcraft HB112)
Original applications: 1973/77 F100/350 // 1975/77 Econoline // 1976/77 Bronco // 1978/79 F100/350, Bronco & Econoline-Use with Speed Control only.
Old 09-11-2010, 08:39 AM
Blown 331's Avatar
Right but the OP says he does not have speed control.
But my 1977 has the relay under the hood just like the above pic.
Old 09-11-2010, 08:53 AM
Since the OP's '79 does not Speed Control, his truck does not have a horn relay.
bloodspoint: Since you live in Cincinnati OH, suggest you visit obsolete parts vendor Green Sales Company (2120 Seymour Avenue / 513-731-3304), who has all the parts catalogs. You can ask them where the horn relay is located.
They will give you the same info I just did. There is no horn relay on 1978/79's without Speed Control.
Green Sales (greensalescompany.com) has the largest stock of FoMoCo obsolete parts on the planet.
Old 09-11-2010, 09:02 AM
Blown 331's Avatar
Ah, I misread what you said in post #8. Its early!
Old 09-11-2010, 11:34 AM
Thanks. Yeah, Green Sales has been very helpful before with my Galaxie, and they've got stuff _nobody_ else has.
Okay, so I'm back to no needing a relay, but I still need to locate the wiring. I'll talk to those guys if I can't find it on my own. If it's part of a harness, chances are it's still rolling around in there somewhere.
Thanks again,
Sean
Old 09-11-2010, 11:38 AM
BTW, while we're on horns, what was Ford thinking putting that one single little wimpy horn on a big ol' Ford truck? Last one I had, I pulled a set of horns I found in a Grand Marquis, and that sounded much better.
I need to figure out how to get juice to it first, but then I think I'm shopping for a better sounding horn.
Old 09-11-2010, 01:55 PM
Yes yours is 77 not a 78 or 79
In 78 -79 trucks w/o speed control DON'T have horn relays.and that is why the horns are so weak.
Details my man !
1988 F-150 Horn variant13 1987 - 1996 F150 & Larger F-Series Trucks 2 08-10-2015 02:43 PM
1985 f150 horn relay??? TheDudeAbides 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 10 08-02-2014 02:38 PM
Horn mdbbrown 1973 - 1979 F-100 & Larger F-Series Trucks 10 01-17-2013 01:22 PM
64 F-100 Horn problem sleddog60 1961 - 1966 F-100 & Larger F-Series Trucks 5 05-18-2009 10:29 PM
Was a horn an option in 1970? lee 1967 - 1972 F-100 & Larger F-Series Trucks 9 10-30-2000 01:57 AM
Tags
1975, 1978, 1979, 2006, duty, f100, f250, fairlane, ford, horn, relay, super, truck, wires, wiring, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
