bushings for the door latch?
I have a 76 f250 with alot of play in the doors when they are closed. The previous owner had wrapped electrical tape around the post on the cab to keep the door from bouncing around going down the road. Does anyone know if there should be any bushings on the rod on the cab that the door latch closes around, or is it just a case of worn parts? thanks
You probably need a door hinge pin repair kit like this one that you can usually get at most parts stores. That will take the play out of the door hinges. When the doors are open, can you move them up and down and see the hinges move?
Door Hinge Repair Kit
You also may need a new door striker bolt that you can also get at most parts stores. That striker bolt is somewhat adjustable, so you may not need it once you get the door hinges repaired.
http://broncograveyard.com/bronco/i-...ker-plate.html
The following users liked this post:
I have a 76 f250 with alot of play in the doors when they are closed. The previous owner had wrapped electrical tape around the post (striker plate) on the cab to keep the door from bouncing around going down the road.
You are speaking of the striker plates, which thread into the door post. The striker plates have a nylon bushing on them that cracks apart, then falls off. The bushing cannot be replaced, as there's no way to R&R it.
D2AZ6522008A .. Striker Plate / Right/Left is the same / Available from Ford and a gazillion autoparts stores.
Fits: 1973/79 F100/880 / 1975/83 Econoline / 1978/79 Bronco, and...
Fits: 1972 LTD/Mercury Marquis/Mustang/Cougar/Torino/Montego/Pinto/Bobcat/Thunderbird/Lincoln / Used on the front & rear doors of 4 door sedans and station wagons.
Fits ALL 1973/79: Ford/Mercury/Lincoln Passenger Cars (except Maverick/Comet) / Used on the front & rear doors.
Fits: 1980/82 LTD/Crown Vic/Mercury Grand Marquis/Fairmont/Zephyr/Granada/Thunderbird/Cougar / 1980/83 Continental Mark VI / 1980/86 Lincoln Town Car / Used on the front & rear doors.
Junkyards: Rear doors get very little usage, so the striker plates are usually like new.
Door Striker Bushings (plastic)
Thats what I thought and couldn't figure out why this is even available.
Since the strikers were used on the front and rear doors of a gazillion passenger cars, one trip to a junkyard will usually give you enough extras to last a millennium.
If you want branny new, it's available from Ford and every autoparts store.
The striker has threads on the end, so it threads on/off the door post. There is no bolts involved.
I'm gonna have to learn how to scan and post parts catalogs pics...or mebbe not, since I'm already besieged enough...as it is.
Kingkong0192
05-11-2017 06:47 PM
hateme
10-17-2015 06:04 PM
JH1975
07-27-2015 03:59 PM
pwjackson42
04-10-2014 06:11 AM
