Battery group 31 or 65? Higher CCA? - Page 2 - Ford Truck Enthusiasts Forums
Old 04-13-2013, 08:38 PM
vellingapa vellingapa is offline
vellingapa is starting off with a positive reputation.
Quote:
Originally Posted by larryjj View Post
Probably with the Costco 65 batteries.
I just replaced my 4 year old megatron pluses with Kirkland brand as the batteries were weakening. Not impressed as the new kirklands are weaker than my 4 year old batteries - drop to 9.8 volts upon starting. They have no problem starting just don't like that low of voltage. I probably did not have to replace the old batteries as in the end found I was loosing a regulator on the alternator.
I expected the Kirklands to be as good as the megateons as I understand the are both made bt exide, have exact same specs so assumed they were the same. Not... Even with new 140 amp alternator.
Old 04-14-2013, 09:11 AM
69cj's Avatar
69cj 69cj is offline
69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future
How long were they on the shelf? Even new batteries should be given a full float charge when installed.
Old 04-14-2013, 10:28 AM
jswartz84's Avatar
jswartz84 jswartz84 is offline
jswartz84 has a great reputation on FTE.jswartz84 has a great reputation on FTE.jswartz84 has a great reputation on FTE.jswartz84 has a great reputation on FTE.jswartz84 has a great reputation on FTE.
I just replaced the original batteries on my 05 with the factory motorcraft batteries. I figured 8 years is a pretty good deal. The local dealership had them for $110 each and gave me a discount to make them $100 each. Just make sure to replace them before they get weak.
Old 04-14-2013, 10:51 AM
Quote:
based on the date if manufacture both had been on the shelf no more than two months (same date for both). Both were floated before install and again when the alternator was replaced a few weeks later. the new alternator goes right to 14.25v upon glow plugs off, voltage is right at 12.5-12.6 before startup and as such I'm confident they are being charged..... Just saying the Kirkland batteries dli received don't have near the staying power the megatron plus had even with a flaky alternator regulator.
'86 F150 302- Which Battery? D Harry 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 11 03-06-2017 09:31 AM
SD'ees; RV'ees & Bater'ees sunuvabug 1999 to 2016 Super Duty 6 05-29-2014 07:18 PM
For Those Needing Batteries Hakkamike Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 0 02-07-2014 04:40 PM
Group 31 Batteries 73strokin 1994.5 - 1997 7.3L Power Stroke Diesel 8 01-07-2013 12:52 PM
Motorcraft 650cca,750cca,850cca??? Supercab 1999 - 2003 7.3L Power Stroke Diesel 15 08-05-2010 03:12 PM
Tags
31r6, 60, 65, 99, amps, batteries, battery, cold, cranking, f250, ford, group, sale, sd, starter, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
