double cardan boot/seal
I already have the new parts. I just need to find the time and dry weather to put the d/s back together. Then I will know for sure that the parts that came in are correct. After I know the parts that I already have are the right ones, I'll order a few more.
Success!!
Well I got around to putting the D/S back together. The parts that came in were correct. I now have a rebuilt rear drive shaft. The seal was a bit of a pain to get on. It is pressed on the end of the shaft. Every socket I had was either too small or too large, but I found a piece of pipe that just barley fit and I got it on. Put the new U-joints in, greased up everything and reassembled.
These parts fit my drive shaft on my Bronco. I make no promises that they will fit your Bronco, but here are the numbers I have.
The boot is from Neapco, part # N2-86-418.
The yoke with ball-N-socket is from Spicer, part # 211631X
Thanks for following up and letting us know how it worked out, and the proper part numbers.
I copied the part #'s into my Bronco file. Too bad we don't have a good repository of Bronco specs/part numbers on this site (or if we do, I missed it), because info like yours is like gold.
Thanks again!
Thanks again!
Thanks again!
Thanks again!
B E A uuuuuuuutiful
My 95 150 Supercab came from the factory with a 2 joint front driveshaft. There was a TSB, so the dealer installed a double cardan (3 Joint) shaft. 175,000 miles later, I decided to rebuild it. Ford had no part # for the shaft, or #'s for parts. Rumor has it that the shaft is an ealier Ranger retrofit. So I pulled the joints, and went to the local friendly Napa with a set of dial calipers, measured the joints, (cap to cap and diameter of all caps), and looked in the back of the Precision catalog. Turns out the front joint is a Ford 1310/Spicer 1330 combination joint and the 2 rear joints are Spicer 1330, and the cv ball socket kit is a spicer 1310. The Precision part #,s are 434-front, 354-rears, and 617-cv ball socket kit, if anyone needs these #'s. The boot was trashed, and no one knew anything about them . Now what? Thanks to this thread, I got a part # and called Fleetpride:
FleetPride: Homepage
$5.45 + tax... I bought three, just in case. They told me that most small truck driveshafts with a non greaseable cv/universal setup use this boot. Their part # is 2-86-418. It is Neapco, they just drop the N prefix.
Great info Buck!!!
---Mike---
Great info Buck!!!
---Mike---
BUMP since this is a hard to find part and all the links on this thread are dead.
I needed one and it took a while to find. The links on this thread are all dead so I found, and ordered, one here. Hope this helps anyone looking for a new CV seal.
Spicer 2-86-418 CV Seal Slinger - Drivetrain America
CPUNeck
43
12-20-2020 10:13 AM
40dog
06-07-2017 06:47 AM
unlucky2.1_7.3PSD
07-19-2016 02:14 PM
