Swaping out a 460 for a 7.3L Diesel - Ford Truck Enthusiasts Forums
Old 09-10-2010, 02:06 PM
dudyone dudyone is offline
dudyone is starting off with a positive reputation.
I have a 1990 E-350 cutaway with a 460 and 3-speed tranny. How hard is it to
swap it for 7.3L diesel. Can get a 1990 7.3L with tranny and computer
from a 1990 E-350 cutaway real reasonable. Of course there is the rebuild cost.
Will it slide in or what do I need to change out.
Old 09-10-2010, 03:01 PM
chicagodragon's Avatar
chicagodragon chicagodragon is offline
chicagodragon has a very good reputation on FTE.chicagodragon has a very good reputation on FTE.chicagodragon has a very good reputation on FTE.
you will need alot more wiring than just the computer. read the thread just below this one
Old 09-10-2010, 03:24 PM
iam sorry, my head is not right (went to the saints game last night) i thought you said powerstroke. the IDI swap should bre pretty straight foward, you will need to get the frame mounts from the diesel and change the pickups in the fuel tanks. the 460 pickups have a fuel pump built into them. try and rob as many goodies as you can from the donor truck. keep us posted with pictures we love pics around here
Old 09-11-2010, 08:33 AM
tr0y tr0y is offline
tr0y is starting off with a positive reputation.
Why do it ? We just picked up a 97 f350 4x4 Dually for 4300 with 110K on it, they are out there and cheap
Old 09-11-2010, 09:15 AM
Midwest Dually's Avatar
Midwest Dually Midwest Dually is offline
Midwest Dually has a good reputation on FTE.Midwest Dually has a good reputation on FTE.Midwest Dually has a good reputation on FTE.
Not in every place are they cheap.. Not to mention, condition wise, there are many out there really lacking. From the sounds of things Troy, you got a heck of a deal and a find, but it takes a lot of looking as passing up many in hopes of coming across that one good one.
I spent two years looking for one. Low milage, not abused, no leaks, PS, options, 4-wheel drive, and so on.. I found several in the $8k range with 400K miles. Diesels hold their value nicely where gassers dont do as well. Many I came across were severally abused. I didnt want to go out and get myself into payments either.
Next best thing.. Take my 94 F-350 CC Dually, dump the crappy 5.8 and gasser load up, and put in a 97 7.3 DIT, along with 4x4. I found a donor truck, with 138k miles, and for $2k.
The other positive to doing it yourself.. You can go through it during tear down and install, and put new seals, o-rings, and other parts in that will refresh that motor and trans, almost giving you a brand new set up!
Old 09-11-2010, 12:16 PM
Thanks guys for all the info
The reason I want to swap out the 460 is that it eats me up on gas.
With a 3 speed tranny it sucks the fuel. Plus I like to hear the sound
of a diesel. There's nothing like it.
Old 09-11-2010, 09:21 PM
I completely understand all too well! Before I started my swap, I had that SB 5.8 in mine. It was horrible on power, and still was aweful with fuel milage. I originally set out to see about swapping out to a 7.5, but then with considering how many miles I could squeaze and fuel economy I realzied going to diesel made the most sense.
This will be a project you will enjoy and have something you wont want to let go of when you are done!!!!
Old 09-15-2010, 11:35 AM
ghunt's Avatar
ghunt ghunt is offline
ghunt is gaining momentum as a positive member of FTE.
Hey dudyone you might check out oilburners.net, lots of stuff over there about such a swap.
And like chicagodragon said, not too awful much to the conversion, although you might want to see if you can get the gauge cluster too for the diesel tach.
E350 what years of doors and rockers will fit?? jinxie 1968-2013 Full Size Vans 1 05-13-2016 09:16 AM
1998 E350 cutaway 15 box truck auto transmission scelogistics 1994.5 - 1997 7.3L Power Stroke Diesel 3 03-04-2014 08:10 PM
transmission compatibility 6.9 and 7.3 labinepoirier Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 11 05-29-2013 03:47 PM
Headers for 1990 E350 7.5L E4OD? BII Plow Truck Exhaust Systems 2 02-27-2013 03:59 PM
What transmissions fits the 460? dudyone Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 4 09-24-2010 03:38 PM
Tags
460, 58, 73, 75, conversion, diesel, f250, ford, gas, idi, oilburnersnet, psd, speed, swap, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
