BOOST GAUGE CONECTION POINT
09-10-2010, 09:51 AM
on
Wondering what is best area to connect boost gauge either the map sensor/manifold line or before the turbo inlet port?
Thanks.
09-10-2010, 10:00 AM
Before the inlet port? What do you mean? Most tee into the MAP sensor line or delete the AIH and use a tapped plug for the fitting. Like this:
09-10-2010, 10:17 AM
Upper left of this photo, you will see the tee-into-the-MAP line technique.
09-10-2010, 09:31 PM
on
What size T fitting is used?
Thanks.
09-10-2010, 09:56 PM
on
I t-ed off the map sensor too.
09-10-2010, 09:57 PM
09-10-2010, 10:27 PM
Mine is teed into the MAP line also.
But I added a regulator after it so the MAP only sees 22psi, but the boost gage shows actual...
09-10-2010, 11:04 PM
on
I circled in red the point where I attached my boost gauge. Is this ok or do I need to move?? Any difference where you connect?
Thanks.
09-10-2010, 11:09 PM
Quote:
Originally Posted by
robjs111
Thanks.
The area you circled is
PRE -IC. You should move it to AIH or MAP sensor line.
Edit: Actually shouldn't make much difference but you could get a leak in one of the four connections before the boost gets back to the cold side of spider and not have an accurate reading, or know you have a boost leak.
pip-clark
16
09-07-2007 09:44 PM
FORDSDOWNER
1999 to 2016 Super Duty
08-27-2007 03:17 AM
ford4lifer
11-16-2006 08:57 AM
Turf Truck
02-06-2004 11:15 AM
myst
01-14-2002 10:48 AM
1999 ,
2000 ,
2002 ,
boost ,
boostgauge ,
f250 ,
f350 ,
gauge ,
map ,
powerstroke ,
reading ,
sensor ,
size ,
superduty ,
wiring
