TSB 09-6-1 - Ford Truck Enthusiasts Forums
2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
TSB 09-6-1
Old 09-09-2010, 06:18 PM
99expy 99expy is offline
99expy is starting off with a positive reputation.
TSB 09-6-1
I had this TSB done at approximately 35,000 miles. Cured the downshift squawk problem. I've started to notice this same sound again at 55,000 miles. It's only going to get more pronounced and will only increase in frequency. My concern is I won't be able to replicate it for the dealer before the 60K waranty is up. Has anyone had to have this TSB worked on twice?
2007 XLT
Old 09-10-2010, 11:05 AM
berry1234's Avatar
berry1234 berry1234 is offline
berry1234 is gaining momentum as a positive member of FTE.
Quote:
2007 XLT
I can't believe you posted this! I just got my truck back from having the SECOND set of friction plates installed. Almost same mileage too. I had 59,200 when I took it in. Drive the truck at about 30mph up a slight slope or hill, let off the gas, then stomp on it. You want it to downshift and this is when the sqawk happens. Do this by yourself then when your good at it, call and take the mech for a ride before dropping it off. Thats what I did.
I am also worried they will go out again in another 30K miles. I would bring that up and see if they will warranty it then. It's not right.
Old 09-10-2010, 05:00 PM
Thanks Berry, I've got to wonder if this is a design flaw. I see your's is a 2008. Do the newer models, 09-11, have this issue also? Are the newer Expy's using the same 6 speed?
Old 09-10-2010, 05:05 PM
berry1234's Avatar
Yeah, there might be minor changes, but it's the same. There is a problem with either the friction plates themselves or how the tranny is so harsh on them. The parts are not that much. It's the labor that is extensive. At least we got a free tranny fluid change out of it.
Also, I had taken mine in for a ticking/marble sound on start up. Turned out to be the timing chain tensioners/gaskets, etc. Got a oil change and radiator flush because of that work.
Old 09-21-2010, 11:08 AM
Dropped the truck off this morning - mentioned TSB and second time this has happened. Service manager confirmed worked for transmission will be covered along with a front axle leak. Didn't need to test drive it with mechanic. I haven't brought up warranty coverage anticipating the next time it happens.
I've got to wonder if it's worth keeping the truck knowing it will probably happen again, every 25-30k miles. I've also had some issues with high speed vibration, 75-80. Seems to be transient, varying with road conditions, geometry and speed. It always happens on curves. Michelin LTX MS2 tires, balanced twice, not road force balanced.
At least my transmission fluid will be changed again.
Old 09-21-2010, 11:11 AM
berry1234's Avatar
Yeah, it's frustrating. I suspect we will see more people with this problem and may some F150's. Is your vibration from the rear or felt on the steering wheel?
Old 09-21-2010, 11:50 AM
Actually it's both, although it seems more noticeable in the rear. I notice the wheel nibble earlier and the rear becomes more pronounced later. On curves the rear vibration becomes significant. Tires have approximately 20k on them. They are slightly wider, P265/70-18, than the OEM tires. I have never had a problem with Michelin tires, although I'm sure it could happen. When I had the OEM Pirelli's on, the truck didn't vibrate.
I read somewhere, in another post, about vibration troubleshooting the rear end and drive shaft. I'm not sure if I need to go down that path.
Old 09-21-2010, 11:55 AM
berry1234's Avatar
I would take the tires back to where you got them and have them road tested. Tell them you are getting bad vibrations. I had a tire with 10K on it have to be replaced it was so out of round. It helped a ton.
Is the tsb/recall list limited ? jdadamsjr Site Announcements 7 08-23-2014 07:45 AM
service update f150 2006 75ivan 2004 - 2008 F150 1 12-21-2012 09:43 PM
Upcoming 30,000 mile service, several concerns to address RM2738 6.4L Power Stroke Diesel 4 12-12-2011 07:58 AM
2005 5.4L Fuel Injector Failure HENDGESK 2004 - 2008 F150 0 11-05-2007 02:06 PM
throttle body tsb someday Modular V10 (6.8l) 8 06-21-2005 12:11 AM
Tags
0910, 0961, 2004, 2007, 2010, bulletins, expedition, f150, f250, ford, problems, rear, tech, tsb, vibration
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
