Costco Batteries - Page 2 - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Costco Batteries
Old 09-09-2010, 11:00 PM
mechelement's Avatar
mechelement mechelement is offline
mechelement has a good reputation on FTE.mechelement has a good reputation on FTE.mechelement has a good reputation on FTE.
I'm very disappointed with Optima batteries. I will never buy another Optima. I have a yellow top in my garage that won't hold a charge. Supposedly you're supposed to hit them with a 100A charge a few times to bring them back. Suuuuuuuuuuuuure.
Good to know about Costco batteries. I'll have to pick up a couple for one of our trucks soon.
Old 09-09-2010, 11:03 PM
SpringerPop's Avatar
SpringerPop SpringerPop is offline
Too old to be too smart..
SpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputation
Quote:
Originally Posted by rbaker6336 View Post
It would be interesting to know if batteries from different store weighed the same or not. 1/2 to 1lb would be hard to feel
Yes, that would have been nice to get a very accurate weight on them. However, a small difference might be seen, due to electrolyte quantity, even if the lead was identical. I was considering going back to them tomorrow with a digital bathroom scale and weighing my old batteries against two of theirs on their shelf, but I think I have better things to do.
You got a good run on the Motorcrafts,don't think I have ever got more than 3 years from the ones I've had in the last 30 years ( could have something to do with the climate )
I live in the San Fernando Valley, where summer temperatures here are frequently above 115 degrees. Our humidity is much drier, which would contribute to greater electrolyte loss. We get freezing temps once-in-a-while in the winter, too. I do, however, occasionally service them with distilled water.
Think my truck is on it's 8th set of batteries now from 2 different stores.Most lasting from 5 1/2 months to 54 weeks
Something is wrong with your regulator system. It's either set too high, boiling the juice out of the batteries and letting the plates get dry, or it's too low, allowing them to prematurely sulphate.
Pop
Old 09-09-2010, 11:09 PM
tdpower's Avatar
tdpower tdpower is offline
tdpower is a splendid one to beholdtdpower is a splendid one to beholdtdpower is a splendid one to beholdtdpower is a splendid one to beholdtdpower is a splendid one to beholdtdpower is a splendid one to beholdtdpower is a splendid one to behold
That's a defibrillator for batteries. I've heard of that but if they won't hold a charge probably won't help.
Good to know about Costco batteries even though I have a Sam's club membership. Good info.......Reps if I can.....
Old 09-09-2010, 11:10 PM
Stangrcr1's Avatar
Stangrcr1 Stangrcr1 is offline
Stangrcr1 has a good reputation on FTE.Stangrcr1 has a good reputation on FTE.
I have brought back two Optimas so far with my Xtreme charger. The pulse charging is what brings them back. Forcing an overcharge only overheats them and burns them out. I have also brought back Diehards and Motorcrafts with this charger. I love it.
And for the cost of one battery?
http://www.xtremechargers.com/
And when I hook it up to the truck, she cranks so much faster with the higher reserve. Can I give reps to Xtreme?
Sorry to derail a bit. Just wanted to share some battery tech I learned....
Old 09-09-2010, 11:22 PM
Don,
Do you leave the Xtreme hooked up as a battery "tender" when not driving the truck?
Pop
Old 09-09-2010, 11:25 PM
rbaker6336's Avatar
rbaker6336 rbaker6336 is offline
rbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to behold
Quote:
Pop
The batteries never boil even after 16 to 18 hrs running (with either alternator) and have never lased long enough to need water added.I'm pretty sure it's the crappy wally batteries one set was from oreally
If it was just one vehicle i would think different but all three do about the same and it's always one battery that goes bad
The set in my truck now are almost 2 yrs old but it's average milage is less than 200 a month,so I may get 2+ years out of these
The good is I've only had to buy 2 sets if batteries in almost 10 years
Old 09-09-2010, 11:33 PM
sledhead999's Avatar
sledhead999 sledhead999 is offline
sledhead999 is gaining momentum as a positive member of FTE.sledhead999 is gaining momentum as a positive member of FTE.
XtremeChargers.com | 12V Battery Maintenance Chargers
Which version are you using?
Here's mine: http://www.oreillyauto.com/site/c/de...0360&ppt=C0005
I've heard shocking the battery with ~100amp for 15min boils em and garbage falls off the plates newing their life.
Old 09-09-2010, 11:36 PM
Stangrcr1's Avatar
Don,
Pop
Not exactly. I will hook it up to the truck, usually over the weekend when I am not driving it, and hook it to one batt Saturday, and the the other Sunday. Monday morning the cranking speed is way up.
I have done this about once a month for the year that I have had the Xtreme and very happy with the results.
You can leave it hooked to both batteries in parallel but it takes longer to work.
If any vehicle at my place gets parked for more than a few days, the Xtreme goes on it and the battery is always good when the vehicle is started. The Cherokee in the backyard has been parked for about a year, but still starts since I put the Xtreme on it every couple months.
The instructions with the Xtreme say you can use it as a "trickle" charger, and it will pulse your battery at low levels while on "trickle", helping maintain charge and battery conditioning.
Old 09-09-2010, 11:39 PM
Don,
Pop
Yeah, exactly. It looks like a battery tender. I can keep it charge when constantly trickling it. If it's not on a charger, it's dead.
Charging an Optima or AGM Battery : Batteries Are Us
Old 09-09-2010, 11:40 PM
Stangrcr1's Avatar
Quote:
Dunno. The one that works?
There is no 'version' number on it.
Old 09-09-2010, 11:45 PM
Stangrcr1's Avatar
You can call the Xtreme a tender as it only provides a few amps charge, (5A max, I think) but the pulsing is what brings them back and reduces sulfation.
I do not know who "Batteries Are Us" is. I bought the Xtreme a year ago and have seen first hand what it has done.
I also have a 200+ amp starting charger that can blast a battery into thermonuclear overload in seconds.
The Xtreme does a better job.
Old 09-09-2010, 11:48 PM
I have a pulse charger. It's for deep cycle batteries. Doesn't work.
  #28
Old 09-09-2010, 11:51 PM
Stangrcr1's Avatar
And upon reading the Batteries Are Us info, I can agree on some of it.
The two dead Optimas I brought back, did get blasted with 200 amps until they got warm, allowed to cool, blasted again, allowed to cool, and then put on the Xtreme. I never allowed them to get hot.
Any battery overheated is only worth recycling.
  #29
Old 09-09-2010, 11:54 PM
Stangrcr1's Avatar
The Xtreme works on deep cycle and regular batteries.
Works on ALL my batteries, even the 12v batteries for my Makita drill.
Damn, now I sound like a salesman.
  #30
Old 09-09-2010, 11:56 PM
Standard Extreme, X2 Dual Station, Xtreme Parallel?
Finally changed my batteries - 6 years porthole 6.7L Power Stroke Diesel 15 12-04-2016 11:29 PM
Dead Battery Revelations Fuzzpuss 6.0L Power Stroke Diesel 30 11-01-2016 09:17 AM
Batteries Pony Power 1999 - 2003 7.3L Power Stroke Diesel 22 12-22-2015 07:24 PM
Extreme cold weather, batteries ..ac delco? rvx290 2004 - 2008 F150 13 10-25-2015 02:28 PM
How to tell when you need new batteries... MC5C 6.0L Power Stroke Diesel 5 06-14-2015 08:05 AM
Tags
2004, 65, batteries, battery, cabinet, chris, costco, explorer, ford, group, lariat, maker, marysville, motorcraft, truck, wa
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
