VALVE BODY MODS
VALVE BODY MODS
IN THE PASS I SAW SOMETHING ABOUT DRILLING OUT SOME PASSES IN THE VALVEBODY . NOW THAT IS TIME TO DO MY TRANS I CAN'T FIND THE PAGES THAT I PRINTED AND OR THE POST THAT I FOUND THEM IN. GOING TO INSTALL A TUGGER KIT SHOULD I ALSO DRILL OUT THE VALVEBODY TO FIRM UP THE SHIFTS ?OR IS THAT PART OF THE TUGGER KIT
Yes, there is drilling that needs to be done in the Valve Bodies (Main and Accumulator). There are bits for that included in the kit. They can also be used to drill the plate, but you'll probably need another one. I drilled my plate to the maximum sizes called for for the diesel application in the instructions.
The instructions are a little confusing, but take your time, and go step by step, one bore at a time. You'll get through it just fine...
Just stick to drilling the points indicated in the Transgo instructions. There have been others who really understood how a tranny works that drilled things without installing the Transgo (might have added the Sonnax modulator, can't remember) to address certain issues, but if you install the Tugger, just drill where it tells you to. You can't undrill a hole, so start simple and if you're not satisfied, search for the other thread again.
Duck Hunter81
39
10-13-2010 06:34 PM
7.3blacksmoke
01-15-2009 04:52 PM
