How to Change Oil Pump on '95 F-150 4.9L - Ford Truck Enthusiasts Forums
Old 09-09-2010, 01:19 PM
jtwalker jtwalker is offline
jtwalker is starting off with a positive reputation.
Several years ago I replaced the oil pan gasket myself and was able to do it just by dropping the pan onto the cross member and fishing the gasket from one side of the pan to the other just by feel. Now I think I may need to replace my oil pump.
Three questions:
1. Can you clean the oil screen just by dropping the pan onto the cross member?
2. Is it possible to remove the oil pump on a '95 4.9L without jacking up the engine (i.e., just by lowering the pan again)?
2. Does anyone have any good pictures of what the internals of the oil pump/crank case? (I've seen the schematics in Haynes and Ford manuals, but I wanted to see real photos).
Any tips on performing this?
Thanks,
JT
Old 09-09-2010, 01:23 PM
fordboyf150 fordboyf150 is offline
fordboyf150 is starting off with a positive reputation.
ive done several of these pumps and your best bet is to jack up the engine, and just put some wooden blocks between the engine mounts and where they mount on the engine at. service information tells you to remove the upper intake plenum but ive gotten away without having to do that. and cleaning the oil screen youll still have to raise the engine because without doin so the pan is only going to drop like 2 inches and that isnt going to be enough seeing as how the pickup goes deeper into the pan then that.
Old 09-09-2010, 01:24 PM
oh! and yes youll have to remove the raidator for clearance
Old 09-09-2010, 01:26 PM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is online now
Diesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud of
Ford boy is correct in everything except for removing the radiatior.
Old 09-09-2010, 01:29 PM
usually on the v8 you can get away without removing it but the inline 6 is a longer block even with the fan and clutch off the water pump shaft still will scrape the fins. might not cause damage like produce a leak but itll scrape up them fins tho. its your call tho haha
Old 09-09-2010, 01:36 PM
I have done 4 300 6cyl and never removed the radiatior
Old 09-09-2010, 01:37 PM
thats awsome?
Old 09-09-2010, 02:42 PM
Thanks Guys. Here are few more questions then:
1. I've never messed with the engine mounts, how many are there and relative locations?
2. Sounds like i may get away without having to remove the intake manifold, how about the connection to the exhaust?
3. What is the best jack point to raise the engine from?
Thanks again,
JT
Old 09-10-2010, 08:54 AM
theres 2 engine mounts and both of them only have 1 nut on top to disconnect them from the engine. ive never had to do anything with the exhaust it usually moves right along with the engine. may have to disconnect a mount or two. and just put a wood or rubber block under the oil pan and jack it up there. and while its holding the motor up put wood blocks (or what i used was hockey pucks) between each motor mount and bracket.
Old 09-10-2010, 10:21 AM
pullnyou pullnyou is offline
pullnyou is starting off with a positive reputation.
i have always removed the intake on all the trucks i have done so you dont' beat the back of the intake up on the fire wall with the extra time it take its sometimes worth it since you dont' have to struggle
1995 300 I6 oil pan gasket change DIY DAT2109 1987 - 1996 F150 & Larger F-Series Trucks 1 07-11-2015 10:36 PM
Pieces of Gasket Fallen in Oil Pan?!? caleballen95 1973 - 1979 F-100 & Larger F-Series Trucks 8 05-21-2014 06:47 PM
Anyone Ever Change an Oil Pan Gasket Without Lifting the Engine? Stickz 1999 - 2003 7.3L Power Stroke Diesel 49 02-17-2013 10:39 AM
Oil pan gasket replacement dogwatch Ford Inline Six, 200, 250, 4.9L / 300 6 01-29-2012 12:54 PM
Oil Leak Question Tod1985F250 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 6 02-28-2009 01:38 PM
Tags
1980, 300, 49, 95, change, changing, engine, f150, f350, ford, motor, mounts, oil, pulling, pump, truck, water
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
