My Truck will not shift into gear. - Ford Truck Enthusiasts Forums
Old 09-08-2010, 11:46 PM
hickboy81 hickboy81 is offline
hickboy81 is starting off with a positive reputation.
Alright gents, as soon as i fix one problem another one pops up. I have 92 f-250 custom 5 speed with a 7.3 IDI. The problem first started today on the highway while i was driving to work and went to shift into 5th gear and she acted like she didn't want to go. I eventually got her to engage into fifth, but when i was coming off the local bypass and started down shifting to stop I couldn't pull the truck out of second gear. I eventually got it out but it took a bit. A little further down the road i came to another dead stop, but this time she wouldn't engage into any gear. I was stuck at an intersection waving people around me. I eventually got her to enage into third and eeked my way out of there. What do you guys think. I think my slave valve might be bad??????
Old 09-09-2010, 08:43 AM
Lazy K Lazy K is offline
Lazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to all
First thing to check is the fluid level in the master cyl resevoir. If low check for leaks. Look under the dash at the pedal linkage for any signs of fluid at the firewall, if any found replace the master cyl. While there check for worn/broken bushings in the pedal linkage.
Fortunately you have an external slave cyl so check for fluid leaks there.
Also check around the firewall where the master cyl bolts on for any signs of cracking/flexing of the firewall when the pedal is pushed down.
5r110-I've never seen that much clutch in the pan pud 6.0L Power Stroke Diesel 10 01-01-2016 01:19 AM
What Just Fried? Jmschneider 1973 - 1979 F-100 & Larger F-Series Trucks 14 09-14-2015 11:10 AM
4R100 Upshift Engagement causes Engine Braking Decipha Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 13 03-03-2015 09:47 AM
1997 F250 5.8L Automatic, is this tranny junk? Har Wood New Member Introductions 0 09-15-2014 03:24 PM
My Theory on cause of 6.0L failure 6L PWR Competition 10 09-09-2010 03:10 PM
Tags
2003, 2007, 87, change, engage, exhibition, f150, f250, ford, gear, gears, shift, shifting, truck, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
