5.0 FI swap into 1973 f250?
the c4 will work just fine. small block bolts up to small block. i ran mine with the 4 speed. i used the bell houshing off a 300" 6, clutch off a 78 302, and the flywheel from a 95. I was pushin 400 hp with it. only problem was i used all the factory 95 wiring, and made it work off the original ignition switch. if i'd known more about the fuel injection set up back then, i woulda used stand alone engine management (like megasquirt) to make it work. its kinda 6 of one half dozen of the other with the performance parts for the fuelie vs carb. only reason i saw for the swap was the mileage increase. i went from 8 with a 390 4bbl, to 14.
dpellicone
11-06-2009 10:17 AM
uriah
05-18-2007 08:58 PM
1987fi50
01-05-2006 09:48 PM
lookingtozion
13
11-28-2004 08:03 PM
