Go Back   Ford Truck Enthusiasts Forums > Misc. > Aftermarket Products
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Aftermarket Products SPONSORED BY:
  #1 (permalink)
Old 09-08-2010, 10:16 PM
DavidY DavidY is offline
Garage is empty, add now
DavidY is starting off with a positive reputation.
Stake Pocket Anchors or Tie Downs
Stake pocket anchors....found this, but it appears to be too big for the stake pockets in my 2010 FX4:
2 pc retractable stake pocket anchors | Tie Down | Medium Duty | Trailer | Princess Auto
I didn't open the package, but did compare the stake pocket opening to the anchor....anchor was too big by about 3/4 to 1 inch.
Any help would be appreciated. Thanks.
Dave
  #2 (permalink)
Old 09-09-2010, 01:13 PM
85e150six4mtod 85e150six4mtod is online now
85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.
Help doing what? They are too big, you should return them.
I prefer these inside the bed:
Ancra Tie-Down Anchor - DennisKirk.com
They also make a track with the same or similar loop part so you can have more location options:
Ancra 72" Tie-down Track (ANC 40467-33-72) - Rack-It
I tried the rubber expanding stake pocket anchors--junk. The pull right out.
  #3 (permalink)
Old 09-12-2010, 07:32 AM
ckal704's Avatar
ckal704 ckal704 is offline
ckal704 has much to be proud ofckal704 has much to be proud ofckal704 has much to be proud ofckal704 has much to be proud ofckal704 has much to be proud ofckal704 has much to be proud ofckal704 has much to be proud ofckal704 has much to be proud ofckal704 has much to be proud of
I have those bull ring tie downs and they fit fine in my '97. I like them and they work great. I can't comment on the stake hole size of a 2010 as I haven't seen them, but I find it odd that Ford would change the size of the holes.
Are you saying that the (yellow on mine) base won't go into the stake hole? The black plastic cap portion stays above the hole and lays flat on the bed rail.
Other than that, I don't really know what to tell you.
__________________
Kal
97 250 PSD Ex Cab Sd 4X4 ZF5 185k
Buncha low budget mods
"I tried being reasonable. I didn't like it."
  #4 (permalink)
Old 09-13-2010, 11:15 AM
I didn't open the package, but did compare the top flat plate to the stake opening and factory plastic bed rails. The Bull plate is too long by an inch or so....leading to me believing that it would not fit properly. Returned the item immediately. I don't think that I would want to start cutting the plastic bed rail to make the stake anchor fit properly.
Dave
Tags
1996, 2010, anchor, anchors, bed, beds, black, cover, downs, f150, ford, pocket, pockets, stake, tie, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
