speedometer not working very hard shifting and engine rev - Ford Truck Enthusiasts Forums
Old 09-08-2010, 01:54 PM
Ford or nothin Ford or nothin is offline
Ford or nothin is starting off with a positive reputation.
I just got my truck back from the tranny shop 3 days ago,was driving down the hiway looked down and my speedo went from 65 to 0 instantly. it was driving fine till i exited then started reving and not shifting till about 3000 rpms. So i changed the sensor on the rear end and the vss on the transfer case but no results. anything i missed or advice o wise ford fans? Please help!!!!!!!!
Old 09-08-2010, 08:33 PM
Bluegrass 7 Bluegrass 7 is offline
Bluegrass 7 has a good reputation on FTE.Bluegrass 7 has a good reputation on FTE.Bluegrass 7 has a good reputation on FTE.
Post
What year and motor?
I'm not clear about the 'revving 'part!
Do you mean just the speedo registers high rpm or the motor revs before shifting?
Are there any codes set?
Is the transmission shifter lamp flashing, near the OD button?
Old 09-08-2010, 09:12 PM
sorry no info
Its a 98 f150 5.4 with 4r100,4x4. it drives normal till about 2200 rpm then revs to 3000 and shifts and bucks like a bull. just had the tranny rebuilt, transfer case had bearings and a fork and pump hose fixed,and new carrier and axles and bearings installed in rear end. the semsor in the rear end was broken so i replaced that then the vss on the transfer case. Just got a call from the secratary at tranny shop she said the mechanic says the problem is in the transfer case come see him at 8am.i want some ammo to go in there with so he dosent gimme the buisness please. thanks for the help
Old 09-08-2010, 09:13 PM
no o/d light flashing either
Old 09-09-2010, 09:57 AM
RobbyMartin RobbyMartin is offline
RobbyMartin is starting off with a positive reputation.
I don't know about the speedo, but my truck would rev high before shifting and I took it to a few tranny shops to get different opinions. One guy suggested that it could be my TPS (throttle position sensor) and I thought he was nuts because it had nothing to do with the tranny. I happened to have another TPS in my garage so I replaced it and my issue was gone. He said when the TPS begins to go bad they develop dead spots and it causes a mis-read and the computer lets the truck rev higher before shifting. It's worth checking out because I was ready to drop some serious cash to have my tranny worked on.
Old 09-09-2010, 11:49 AM
cool thanks i just got back from the tranny shop and he told me the gear inside the trasnsfer case that runs the vss was broken because he stuck his finger in there and didnt feel it but when he spun the vss it registered on the speedo. so im going to try and replace it myself. im no super mechanic but im not paying 1000 bucks to replace a plastic gear... no way!!!!! ive r/r trans in older f250s and old mustangs so I figure gettin it out is half the battle. anybody have any advice on replacing that gear? I would like to get sum idea of what im jumping into. thanks in advance
Old 09-14-2010, 07:24 PM
got it fixed the keeper for the plastic gear on the main shaft on the transfer case came loose so i got a new one and reinstalled the gear. she runs like a dream now.
Old 11-27-2013, 07:52 PM
djordan djordan is offline
djordan is starting off with a positive reputation.
where did you get the new keeper???? or is that something that comes on the new sensor
5 hours drive with the 69 f100.. forestgreen 1967 - 1972 F-100 & Larger F-Series Trucks 6 04-20-2016 09:22 PM
Help transmission trouble on an 2006 F150 5.4 triton jadesdad 2004 - 2008 F150 3 08-14-2015 12:45 PM
E4OD acts up when warm brendo907 Clutch, Transmission, Differential, Axle & Transfer Case 9 06-20-2015 09:49 PM
No Shift From 1st in D billdavis538 1997 - 2003 F150 5 05-12-2014 09:26 PM
tranny question jpeckham Clutch, Transmission, Differential, Axle & Transfer Case 12 03-11-2013 03:12 AM
Tags
2001, 2004, 73, escape, f150, ford, hard, high, navigator, reving, revs, shifting, speedometer, tranny, truck, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
