Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > 4 Cylinder Engines
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 09-08-2010, 12:47 PM
bolivartech bolivartech is offline
Garage is empty, add now
bolivartech is starting off with a positive reputation.
Question 2.5L with fuel pressure problem
I have a 2000 Ford Ranger with a 2.5L. I have been having trouble getting it to start so I started by replacing the fuel filter as it seemed like I was having trouble getting fuel to the motor at ignition. It runs just fine, only starting is the problem. I checked the pressure with the motor on, 65psi. With it off I could actually see the gauge drop from 65, relatively quick. Someone mentioned to me it could be the fuel pressure regulator or a check valve in the fuel pump. Does anyone know if those can be replaced individually, or if it could be something else?
__________________
Levi
_______________________
2000 Ranger XLT 2.5L 5spd
1972 F100 Sport Custom 360 A/T
Tags
2000, 2001, 25, 25l, cyl, engine, ford, fuel, injector, pressure, problems, ranger, regulator, replace, specs
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
