How much does a 6.9L weigh? / Compression test question - Ford Truck Enthusiasts Forums
Old 09-07-2010, 10:03 PM
Ford F834's Avatar
Ford F834 Ford F834 is online now
Ford F834 has a very good reputation on FTE.Ford F834 has a very good reputation on FTE.Ford F834 has a very good reputation on FTE.
Hi guys,
I can't seem to find a specification for the weight of a 6.9L complete engine... I think my engine stand is rated for 1,200 or 1,800 lbs. (I can't read the sticker any more). If I do end up pulling my engine I need to know if I need a bigger stand. I have a 3 ton chain pull to get it out, so that won't be a problem.
Also, before I make the decision to pull it, I want to do a compression test (see my thread about running low on oil), but I am having trouble finding an affordable compression tester for a diesel application. I actually only found one vendor, and the price was over $200 because it's a kit with adapters for many engine types. Is this par for the course or??? Seems like for that much I should just have a shop do it (if I can find one I can trust ) Seems like I read a thread here that mentioned a compression tester could be had for $40. I found gas engine testers for that price, but they maxed out at 300 psi, and the Haynes Techbook says the 6.9L should read between 220 and 440 psi. Does this range seem right? Huge difference between 220 and 440.
Old 09-07-2010, 10:19 PM
GenLightening's Avatar
GenLightening GenLightening is offline
GenLightening is starting off with a positive reputation.
Fully dressed they run about 1100lbs. Get the biggest stand you can. Mine is rated for 2000lbs and it sagged pretty good. The comp test range is the lowest should not be less than 75% of the highest (some have seen up to 550psi). Spend more for a better tester, some of the cheapies don't last for more than a few cylinders.
Old 09-07-2010, 10:33 PM
poocher pup poocher pup is offline
poocher pup is starting off with a positive reputation.
mine went closer to 1400lbs without any acc. 2 ton engine hoist picked it up easy, motor stand drooped front of motor 3" while on it.
Old 09-07-2010, 10:37 PM
oreocreaming's Avatar
oreocreaming oreocreaming is offline
oreocreaming is gaining momentum as a positive member of FTE.
1400 lbs? thats excessive man. did you scale it out? that seems a couple hundred lbs overweight.
Old 09-07-2010, 11:01 PM
no just a close guess as to how much it squated my truck with it in bed. it was still full of oil though.
Old 09-07-2010, 11:17 PM
24 lbs or so for oil, 32 lbs for water in the block. i know my turbo engine was murder on the lil mazda b2300 when i picked it up lol but im not sure a weight. my scale only goes to 600 lbs so i cant get a weight on it. i know my loaded heads are 95 lbs each.
Old 09-07-2010, 11:24 PM
charleswood6969 charleswood6969 is offline
charleswood6969 is starting off with a positive reputation.
I put my spare on a scale. Without alternator but everything else on, it scaled at 1291 lbs. It is a 1983, and I hear that 1985 and up are heavier due to internal stress webbing.
http://www.ford-trucks.com/forums/pi...528763&thumb=1
Old 09-07-2010, 11:30 PM
http://www.ford-trucks.com/forums/picture.php?pictureid=44155&albumid=10306&dl=12825 28763&thumb=1[/IMG]
Old 09-09-2010, 05:23 PM
rangernut09011980's Avatar
rangernut09011980 rangernut09011980 is offline
rangernut09011980 is starting off with a positive reputation.
Quote:
Originally Posted by Ford F834 View Post
Hi guys,
COMPRESSION TESTER HARBOR FREIGHT 19.99 149.99
the 19.99 1 will test most anything us Hobby guys will ever do. But the 149.99 wil test virtually every diesel ever built LOL
Old 08-09-2014, 10:38 PM
kevin p kevin p is offline
kevin p is starting off with a positive reputation.
I need to no how much my 91 7.3 weighs so I don't drop it when I pull it.i plan on pulling it complete. can someone tell me
Old 08-09-2014, 11:08 PM
hairyboxnoogle's Avatar
hairyboxnoogle hairyboxnoogle is online now
hairyboxnoogle is gaining momentum as a positive member of FTE.hairyboxnoogle is gaining momentum as a positive member of FTE.
It says in the top of the thread... A factory turbo 7.3 weighs around 1250 fully dressed. NA engine would be around 1100-1200.
Preparing for the 7.3 to 6.9 Swap on my IDI Van genscripter Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 3 01-01-2017 10:52 AM
6.9 IDI Low Compression Numbers? phil_idi Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 15 05-20-2013 11:13 PM
Need feedback on My 86 6.9 Compression test?????????? blazinjames Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 7 06-28-2012 07:22 PM
Host of Problems w/ Newly Purchased 2001 7.3 Drivend 1999 - 2003 7.3L Power Stroke Diesel 28 11-11-2009 11:22 PM
6.9L Diesel Compression? turboman24 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 11 06-22-2008 08:29 PM
Tags
1994, 69, 69l, compression, diesel, engine, f150, f250, ford, liter, motor, pulling, specs, troubles, weigh, weight
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
