Cab mounts for a 1990 F250? - Ford Truck Enthusiasts Forums
Old 09-07-2010, 09:06 PM
CrazedPanda CrazedPanda is offline
CrazedPanda is starting off with a positive reputation.
I have looked high and low for cab mounts for a 1990 F250 with no luck. I would think some company would make them considering it being a common rust prone area. Ive found many floor pans but no mounts! Ive checked JCW, LMC, Raybuck, Mill supply?, Keystone no mounts only pans. has anyone found any mount kits or do i need to find a truck with decent ones and cut them out?
Old 09-07-2010, 11:38 PM
old_lynrd old_lynrd is offline
old_lynrd is starting off with a positive reputation.
autozone can get them...they r made by energy suspension and they r made of polyurethane so they will last forever
Old 09-08-2010, 08:31 AM
not the cab bushings. i need the mount, the part that sits on the bushing attached to the cab.
Old 09-08-2010, 09:49 AM
nstueve's Avatar
nstueve nstueve is offline
nstueve has a great reputation on FTE.nstueve has a great reputation on FTE.nstueve has a great reputation on FTE.nstueve has a great reputation on FTE.
cut them off another cab, or fabricate your own... I made a set of heavy duty ones so i wouldn't have to worry about rust again.
Old 09-08-2010, 02:30 PM
Ohio Ford Farm's Avatar
Ohio Ford Farm Ohio Ford Farm is offline
Ohio Ford Farm is gaining momentum as a positive member of FTE.Ohio Ford Farm is gaining momentum as a positive member of FTE.
Quote:
I agree here. The problem with this year span of the trucks. ( I love the 87-91 F trucks ) is there to new for the aftermarkets to make some of the hard parts and too old for Ford to still make. I would check with a local dealer as they might have been the same for years newer and if so would still be available. If not your best bet will be a junk yard or making a new set on your own.
Are you looking for the part on the Cab, or the part on the frame?
Old 09-08-2010, 02:37 PM
part on the cab, i work at a ford dealer and its not available anymore.
Old 09-08-2010, 04:06 PM
Quote:
Yea that's going to be a very hard to find part. like I said maybe a junkyard out west or fab your own. I wish you the best of luck I know what kind of a pain it is to try to find some of the stuff for these years trucks.
LMC has mounts for 80 -86 I wonder how much change they made? there like $70 each thoe! Might be pricey chance?
http://www.lmctruck.com/icatalog/fd/full.aspx?Page=21
Old 09-08-2010, 06:40 PM
fordyduty fordyduty is offline
fordyduty is starting off with a positive reputation.
Autoabody Specialties in Middle Field CT has someone in house that fabs them. I bought some for my 88 f250 resto. They are a pretty big company and speacialize in many makes and model trucks and cars. I think they have a website as well. They don't fit perfect but then again almost none of the aftermarket sheetmetal does.
Old 09-08-2010, 07:47 PM
AWESOME! thank you, i knew somone out there must know of them. if anyones interested heres the website Auto Body Specialties, Inc. its part number f-288
Old 09-08-2010, 08:42 PM
Glad I could help. If your going through the trouble of replacing the cab mounts buy the front pan as well. It will make life much easier. Also be sure to weld in some bracing between the pilliers. I will try to post some pics or I can send you some pics via email showing the step by step process I did to replace them.
Old 09-08-2010, 09:07 PM
yes please send some pics if you can. I already have the floor pan, right now im fixing where the a piller meets the floor
Old 09-08-2010, 10:13 PM
click on my name and take a look at the album i created. I am working on finding the rest of the pics that I took. Let me know if you have any questions. I may have done an overkill in some people's eyes but my work will still be on the truck and solid for years to come.
Old 09-09-2010, 09:55 AM
Quote:
Must say .. Very nice looking work there.
Old 09-09-2010, 11:00 AM
pictures are very insightful. the other cab mount was repaired before i got the truck and looks awful so i wasnt exactly sure how it went. thanks for the pics
1990 f250 frame cross member turbosporsche 1987 - 1996 F150 & Larger F-Series Trucks 1 10-28-2015 12:17 PM
Rocker panel, floor pan, cab mount replacement mgeorge0090 Paint & Bodywork 2 06-07-2015 02:16 AM
Front cab mounts jemini 1987 - 1996 F150 & Larger F-Series Trucks 4 12-25-2014 10:01 AM
F250 Floor Pans dad50+ 1987 - 1996 F150 & Larger F-Series Trucks 4 07-20-2013 05:15 PM
replacing floor pans/cab mounts some help crazed87bronco 1967 - 1972 F-100 & Larger F-Series Trucks 17 11-08-2010 11:31 AM
Tags
1988, 1990, 1991, 4x4, 89, brackets, cab, f250, ford, mount, mounts, replace, rust
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
