Chrome Moto Metal 955's on F250 - Ford Truck Enthusiasts Forums
Brakes, Steering, Suspension, Tires, & Wheels Click Here
Old 09-07-2010, 06:54 PM
T-Bolt T-Bolt is offline
T-Bolt is starting off with a positive reputation.
Hey fellas,
I'm interested in running these wheels on my 1999 SD 4X2 F250. The suspension is stock. I'm torn between the 18X9's or the 20X10's. Through some research if I ran the 18X9 I would need 4.5BS with -12MM offset and 20X10 would require 5" BS with -12MM offset. Does that sound about right? I do not want the tires pouching outside the fenderwell more than a 1/4" if possible.
I'm looking to run a 275 series tire as I pull my travel trailer with the truck and I would rather not lose my low-end torque by running a taller tire. I'm not sure if width will be a factor on a 275 series tire. I doubt it although I just wanted to get a second opinion.
I have yet to see these wheels on an F250. Please post up if you have them.
Thanks in advance!
Ron.
Aftermarket rims with +10mm offset a24banas 1999 to 2016 Super Duty 0 01-18-2015 08:46 PM
Need opinions on wheel/offset-aplogies in advance. LSBoogie 1999 to 2016 Super Duty 0 06-28-2014 06:03 PM
Wheel help 02 Stroker 1999 - 2003 7.3L Power Stroke Diesel 3 05-12-2013 09:07 PM
Wheel/tire questions 06silvercrew 1999 to 2016 Super Duty 18 09-22-2010 12:23 PM
03 F250 4" Lift...20x10 -43mm BS:3.75 fit with 35s? VEECON Brakes, Steering, Suspension, Tires, & Wheels 4 02-01-2010 11:03 AM
Tags
08, 18, 250, 955, chrome, duty, excursion, f250, ford, metal, moto, motometal, super, truck, wheels
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
