Cruise Control Problem/1992 F250 4X4 S-Duty LB - Ford Truck Enthusiasts Forums
Old 09-07-2010, 02:34 PM
OleLoop OleLoop is offline
OleLoop is starting off with a positive reputation.
Red face Cruise Control Problem/1992 F250 4X4 S-Duty LB
I have to push brake pedal twice to disengage cruise control is there a fix for this? Or a recall? I just bought this P.U. recently so I don't know the history of said Truck. I am new to forums, not new to vehicle repair.
I would appreciate any info. Thank You.
Old 09-07-2010, 02:55 PM
polarismuddman's Avatar
polarismuddman polarismuddman is offline
polarismuddman is starting off with a positive reputation.
Yes, there is a recall on the cruise control......take it to the dealer and give em your vin number, they can tell you for sure if the recall has not been done to it.
Old 09-08-2010, 11:03 PM
rla2005's Avatar
rla2005 rla2005 is offline
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
The cruise control recall was for '93 and above trucks. The '92 and below do not use the same type of cruise de-activation switch as the '93 and above that are prone to causing fires.
My '92 F350 takes a pretty good push on the brake pedal to get the brake light to come on as well as deactivate the cruise. The brake on/off (BOO) switch is a goofy setup. I replaced that as well with no real improvement in the response to pushing on the brake pedal.
Old 09-09-2010, 12:23 PM
Thank you. Sounds like the same problem. It will be a good place to start.
Thanks
Old 04-22-2013, 04:16 PM
bootmaker's Avatar
bootmaker bootmaker is offline
bootmaker is starting off with a positive reputation.
I have installed cruise control on my 1992 F250 HD O/8600LBS.
What I am getting is it works but, it drops down 5 miles an hour before kicking the speed back up. What might be the cause?
cruise control not working Orlie 1999 to 2016 Super Duty 86 02-03-2017 08:25 AM
Cruise Control Don't work. where do I start? Stuckinthemuddd 1999 to 2016 Super Duty 4 04-02-2015 01:49 PM
cruise control for the 1993 ford9303 1987 - 1996 F150 & Larger F-Series Trucks 0 04-30-2014 11:21 AM
Cruise Control dmccorkle911 1973 - 1979 F-100 & Larger F-Series Trucks 2 02-06-2014 10:34 PM
cruise control karenmascaro 1987 - 1996 F150 & Larger F-Series Trucks 2 07-12-2013 02:29 PM
Tags
1992, 92, control, controll, cruise, crusie, f150, f250, f350, ford, inop, problem, problems, wont, work, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
