how much transmission fluid? - Ford Truck Enthusiasts Forums
Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator
Old 04-21-2001, 05:32 AM
bluesky bluesky is offline
bluesky is starting off with a positive reputation.
My owners manual says that I have 16.4 qt. of transmission fluid in my '97 5.4L Expy.
When I inquired about a transmission fluid & filter change at a service shop, The check-in technician scoffed at this volume. He said that I would only need about 6 qt. in a routine fluid and filter change and that the rest of the volume would remain in the torque converter.
Which is correct?
I have 45K miles now and would like to switch to Mobil-1 synthetic transmission fluid for towing purposes. I have misgivings of leaving 10 quarts of old fluid behind if the normal practice is to only change 6 qt.
Thanks for the feedback...
Dino F.
homepage: http://www.geocities.com/blueskywhiteclouds
Low-Tech Ideas, Tips, Hints and Solutions for RV Trailering
Old 05-18-2001, 09:52 PM
As a follow-up to my own question...
Last week I took my Expedition to my Ford dealer for transmission service. I gave them 3 cases of Mobil-1 ATF fluid that I had purchased elsewhere, and asked that any unused fluid be returned to me.
They dropped the pan, cleaned the sediment and magnet, etc.
I got 3 of the 18 quarts back unused.
Dino
Old 08-06-2001, 11:47 PM
TheHobbit TheHobbit is offline
TheHobbit is starting off with a positive reputation.
There is a rubber plug in the bottom of the bell housing, and a corresponding 11mm plug in the converter. Ford reccommends that the converter be drained with each trans service hence the 16 qts. You may have to turn the engine to get the plugs to line up...
Old 08-09-2001, 05:04 PM
ghoughto ghoughto is offline
ghoughto is starting off with a positive reputation.
Manual Transmission Fluid (ZF6 six-speed) corksil 1999 - 2003 7.3L Power Stroke Diesel 6 12-01-2015 11:18 PM
Full Tranny Fluid Pump Out pawpaw Ranger & B-Series 17 04-26-2014 09:52 PM
Fluid ammounts Talyn 1994.5 - 1997 7.3L Power Stroke Diesel 2 11-08-2013 06:54 PM
66 F100 cruiseomatic transmission fluid ford66 1961 - 1966 F-100 & Larger F-Series Trucks 3 10-30-2009 06:31 PM
Notes on 4R100 filter/fluid change; have a good Memorial Day vze2sgxa Expedition & Navigator 5 05-29-2009 03:15 PM
Tags
01, 06, 1966, 1999, 2001, 2006, 54l, amount, expedition, f150, f250, fluid, ford, quarts, transmission, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
