Guages
I also have a setup in my dash with autometer gauges. The mechanical speedometers have a threaded back so the stock speedo cable will not work. You'll have to get a new speedo cable with the 5/8" thread for the speedometer. The price of the cable depends on the length you need. You could also go electric, but very expensive and requires a speed sensor for the transmission. The fuel gauge is much easier. You just need the right fuel gauge compatible with the Ford Ohm fuel sender. I went with all electrical gauges and I just spliced into my harness, but kept the original socket so if I ever want to put the stock dash back in, all I have to do is plug it back in. Here is mine. The pic is of the mechanical speedometer, but I went with electric instead because I had speedometer cable issues and just said screw it and did the electrical thing.
The three gauge setup like fmc400 has will do you just fine and sunpro isn't a bad brand easier. Much cheaper and will get the job done.
To be quite honest, I've run cheapies when money is tight and I've run top dollar gauges...I'd venture to say there is a difference in tolerance, but the cheap onces won't be more than 5% off. So unless you're dealing with a reeeeal fine tune, I wouldn't worry about the brand of gauges. Just get the gauge(s) that monitor what you wanna keep an eye on.
Parts Guy Wyatt
Vendor Specials, Discounts, Product Announcements & Group Buys
08-11-2012 09:49 AM
Wyatt66f100
04-20-2009 08:05 PM
Wyatt66f100
01-16-2008 04:31 PM
BrianA
02-23-2003 06:46 AM
