Edge Evoulution Racing Programmer
I have a couple of questions that I hope someone on here will be able to answer, I purchased an Edge Evoulution Programmmer and did not notice until I got it home that it was the racing edition, anyway I am going with the DPF delete and was wondering if anyone has towed with this programmer? I have a 13000# FW and towed it in level 2 on the way to camp and on level #1 on the way back and there seemed to be no problem.
Also, what are some of the tolerences for the 08 6.4 as I want to set the alerts up?
Transmission fluid temperature max
EGT's max
Engine Coolant
Thanks
Rob
EGT's max
Engine Coolant
Thanks
Rob
Rob
I have the same tuner, went to 4" exhaust and an AFE intake kit. I tow on level 2 because I want to keep the EGT down but use it everyday on level 4. I think one of the big differences is how fast the turbo spools up. On a recent highway trip without towing I got awsome mileage on level 4. The temperature limits should be coolant at 205, transmission at 195 and egt I set at 1150 just so I get a little warning but apparentley you are good to 1450. I just like to know when I'm pushing it a little. When I spoke to Edge they said I wouldn't hurt anything if I kept my EGT's below 1450.
HEY GUYS
HEY GUYS I HAVE A COUPLE OF QUESTION HOPE YOU GUYS CAN ANSWER THEM...IAM NEW TO FORD AND DIESEL TRUCKS.. HOW MUCH DID U GUYS PAY FOR THIS TUNER DID IT COME WITH THE DELETE PIPE?, WHO DID U GUYS BUY IT OF FROM..??AND WHY DID U GUYS GO WITH AN EDGE TUNER.? THANKS HOPE U GUYS CAN HELP ME.
You will notice a big difference in power and fuel mileage when you remove the dpf. I used the AFE si which has the extra scoop facing the front grill to allow more air. I have never thrown a code with it. It makes the truck sound a little throatier more response and a little better mileage. I just have always believed the more air in and the more air out is the best. I am very very happy with the tuner, the exhaust, and the intake. I wouldn't change a thing. I went to edge because I have had lots of their tuners in the past and have been very happy with the products and service. The other thing was I didn't want a 300 hp tune and risk other componenets of the truck. I basically wanted more power and better mileage and the ability to delete the dpf. Rob, when you remove the dpf, take a look inside it and try to figure out how any air moves through it at all!
both cat and dpf lowest I've seen is $225.
tuners are 500 and up.
Sam
I usually get around 18mpg (US) highway with mine before the delete cruising at 108 to 110kph. I am hoping for 21+ afterwards...we'll see. I have it installed now, but I am running stock as my delete pipe has not arrived yet. This way I can get a good idea of the temps before and after anyways.
wantahertzdonut
13
06-13-2013 02:21 PM
dieselchicks
03-05-2011 08:13 PM
audioguru76
22
09-01-2009 05:08 PM
jakermc
12-07-2007 10:42 AM
