Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1957 - 1960 F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1957 - 1960 F100 & Larger F-Series Trucks Discuss the Box Style Ford Trucks SPONSORED BY:
  #1 (permalink)
Old 09-06-2010, 07:57 PM
RUN4CVR's Avatar
RUN4CVR RUN4CVR is offline
Garage is empty, add now
RUN4CVR is starting off with a positive reputation.
My 58 F100 project
I bought this 58 F100 on the 4th of July and thought I would show some of the progress let me know what you think
Click the image to open in full size.
  #2 (permalink)
Old 09-06-2010, 08:23 PM
telefunkken telefunkken is offline
telefunkken is starting off with a positive reputation.
wow you ain't playin around, i'm diggin the build, looks outstanding so far, keep sendin.
  #3 (permalink)
Old 09-06-2010, 10:08 PM
old58's Avatar
old58 old58 is offline
old58 is starting off with a positive reputation.
Wow, looking good. I love that body style, and have a 58 stepside that I have owned since 1976. Great trucks, great job.
  #4 (permalink)
Old 09-06-2010, 10:12 PM
arctic y block's Avatar
arctic y block arctic y block is offline
Old School
1962 Ford F-100
arctic y block has a spectacular reputation.arctic y block has a spectacular reputation.arctic y block has a spectacular reputation.arctic y block has a spectacular reputation.arctic y block has a spectacular reputation.arctic y block has a spectacular reputation.arctic y block has a spectacular reputation.arctic y block has a spectacular reputation.arctic y block has a spectacular reputation.arctic y block has a spectacular reputation.arctic y block has a spectacular reputation.
You kicking butt. Good work
__________________
85 XLT Bronco 351W HO 4V Dual Pipes 33X12.5 BFG's
62 Uni 390 C6 Custom Cab Not Yet Sold
Looking to buy a 48/50 F Anything If ya have one contact me.
Don't just Modify it Fordify it
  #5 (permalink)
Old 09-06-2010, 10:32 PM
RUN4CVR's Avatar
Thanks heres the engine 2002 Navigator 5.4 with a Sullivan carb intake
Also the wheels are just for rolling I will be using somthing else as soon I can get the body back on to figure the right back spacing
Thanks again
Jeff
  #6 (permalink)
Old 09-07-2010, 01:36 AM
2losteve 2losteve is offline
2losteve is starting off with a positive reputation.
2losteve 2losteve 2losteve
Grreat progress on a fitting project.
  #7 (permalink)
Old 09-07-2010, 04:45 AM
Walston's Avatar
Walston Walston is offline
1960 Ford F-100
Walston has a good reputation on FTE.Walston has a good reputation on FTE.Walston has a good reputation on FTE.
Great looking truck and GREAT progress! Keep us posted.
__________________
Walston
http://bigjohnstractor.com/
  #8 (permalink)
Old 09-07-2010, 09:19 AM
59flatbedford 59flatbedford is offline
59flatbedford is starting off with a positive reputation.
wow you are much more ambitious than me on my project. looks like very clean work and should be an awesome truck.
  #9 (permalink)
Old 09-07-2010, 11:39 AM
Corner Gas's Avatar
Corner Gas Corner Gas is offline
2006 Ford F-250
Corner Gas has a good reputation on FTE.Corner Gas has a good reputation on FTE.
Wow!! you are doing fantastic. That looks great.
__________________
Colin
2006 F250 CC Larait-FX4, ScangaugeII, High Idle mod, Heated mirror switch mod. Sinister bypass oil filter and coolant filter.
1981 Ranger F150, 4X4 Trailer special
1966 Mercury F500 Still working hard
1950 F68 Flatdeck
  #10 (permalink)
Old 09-07-2010, 11:59 AM
Tomget's Avatar
Tomget Tomget is offline
Tomget is starting off with a positive reputation.
Run4cvr
Wow you got a pro build going on!! nice Love your rotisory with the frame etc. I'm pleased to see someone could get the "huge" cab off the frame.
I've got a 58 too. Style side. Same as yours except I've got the Custom with the big rear window. I actually left the cab on the frame and tilted it up and supported it from either the front or rear depending and worked around the thing etc. Wasn't set up to get that big thing off by myself. My way worked fine but really like how you did it too.
I'm wild about that Navigator motor. I'm curious your going with a carb? All good. Just surprised. You dont' want the computer stuff?
What tranny are you using? I really like your chassis and the 4 bar rear suspension/all. Really a good setup. What is that differential. I can't always id them from a photo. Sometimes yes/sometimes no.
My 58 is pretty modded too but I kept the front I beam. And I'm happy with that, but i can't attain the low/useable ride height that you'll be able to get. My front is a little higher than I like. Not terribly so, but I'm already using the mono front springs and and test fitted a set of the reverse eye monos but there was just not enough suspension travel remaining for my liking. So i didnt' use the reverse eye monos. They'd be good for "cruisin low and slow" but even though my truck isn't for hauling loads etc, it still needs some "suspension" up front.
Check my gallery for some photos of the build.
Goodluck fellow "4 headlight guy", and maybe you know but if you don't --when it comes time to wire your headlights the only 4 headlight relay I found available is the NAPA Echlin part #AR703 (also a #V07240-don't know what that number is? but its also on the box). And that relay still works great.
__________________
Tom
1948 F-1 312Y,oem4spd,Holley 2150,Merc diff
Other projects: 48IH chopped&channeled,58F100 460 C6 4link pro street
  #11 (permalink)
Old 09-07-2010, 01:17 PM
RUN4CVR's Avatar
Thanks for the comments I'm using a C-4 with a JW bellhousing and flex plate
And when I picked the cab up I used the bat that in the first cab pic that goes from the hood hinges with a cherry picker and my brother and I picked up the back corners so my wife could roll the chassis out the back then set it down on the blocks at the cab mounts
The rearend is out of a 2000 Ford explorer 8.8 with disc brakes 3.73 gears and 31 spline axles
I got an American auto wire Highway 22 harness for it so I can add to it as I get futher
down the road adding stuff like A/C power windows some day just trying to get it running first
I just ordered a 69 Mustang 20 gal fuel tank to put between the rails at the rear of the frame
well back to work
Thanks again
Jeff
  #12 (permalink)
Old 09-13-2010, 08:09 PM
RUN4CVR's Avatar
Here are some more update pictures got th firewall all cleaned and painted with DP90 primer I might just leave it this way I think it looks good and it won't see the sun much to fade it
also I didnt paint it with brushes under the truck those are from doing POR15 on the bottom of the cab and it looks like I need to replace the front cab braces
so I just ordered those
Jeff
  #13 (permalink)
Old 09-13-2010, 08:26 PM
Tomget's Avatar
Wow your cab/doors/even the glass rubber/and especially the wing windows etal looks in great shape for the beginning of a project. Was it all OEM and just kept out of the weather? Or did someone clean it up earlier in its life?
__________________
Tom
  #14 (permalink)
Old 09-13-2010, 08:30 PM
Old School
1962 Ford F-100
Just a thought but from my experience the primer on the fire wall will suck up oil and grim and be impossible to keep clean. It prolly aint the same primer I used. But something ya can polish I found made the engine compartment look finished. Not tellin ya what to do, just telling ya what I went through. Kinda a heads up cuz I ended up redoing mine and after it is together and haveing to pull in engine to do it right made me think I should say something Bud.
__________________
  #15 (permalink)
Old 09-13-2010, 10:31 PM
RUN4CVR's Avatar
Thanks for the info I will check into it some more
also the rear glass and the wing windows still say FOMOCO
on them I cant find it on the side windows or windshield.
were those marked as well?
The wing are bubbling in the glass but I will leave them for a while
as it adds some of the vintage to it
I'm also leaving the faded paint for now I just did the chassis
to make it ride and drive better and look lower
Thanks
Jeff
Tags
58, f100, ford, header, options, project, sale, size, stock, tire, truck, vin, wall, wheels, white
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
