f-250 power window problem - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Old 09-06-2010, 06:39 PM
cdasherm cdasherm is offline
cdasherm is starting off with a positive reputation.
The drivers door power window went down and will not come up. Am I looking for a problem with the switch, or in the motor itself. Any secrets as to getting the door panels off with ruining the snaps. This is on a 97 F-250 7.3.
Old 09-06-2010, 07:34 PM
ckal704's Avatar
ckal704 ckal704 is offline
ckal704 has much to be proud ofckal704 has much to be proud ofckal704 has much to be proud ofckal704 has much to be proud ofckal704 has much to be proud ofckal704 has much to be proud ofckal704 has much to be proud ofckal704 has much to be proud ofckal704 has much to be proud of
It has been my experience that it is pretty hard not to ruin at lest some of the snap fasteners that hold the door panel on.
You can get new ones fairly cheap right at the dealer or at one of the chain auto parts stores in their "Help!" section.
Unless someone out there knows a trick that I am not aware of.......
Old 09-06-2010, 07:52 PM
91 Dually 91 Dually is online now
91 Dually is gaining momentum as a positive member of FTE.91 Dually is gaining momentum as a positive member of FTE.
one of those long flat pry bars (maybe it's called a wonder bar) works for me. Just get it under there as close to the snap fastener as possible and pop them out. I changed one of the rear window motors because of this. Now it only refuses to go up or down SOME of the time :-)
Old 09-06-2010, 09:00 PM
plgebbia's Avatar
plgebbia plgebbia is offline
plgebbia has a good reputation on FTE.plgebbia has a good reputation on FTE.
There is an apholstry tool that is made to remove those clips, it makes it much easier.
If it went down but not back up, it is probably the motor itself.
Old 09-07-2010, 10:18 AM
Brown Falcon's Avatar
Brown Falcon Brown Falcon is offline
Brown Falcon has much to be proud ofBrown Falcon has much to be proud ofBrown Falcon has much to be proud ofBrown Falcon has much to be proud ofBrown Falcon has much to be proud ofBrown Falcon has much to be proud ofBrown Falcon has much to be proud ofBrown Falcon has much to be proud ofBrown Falcon has much to be proud of
I have seen plastic pry bars made to take them off without hurting anything...
I need to figure out my window/doorlock problems. My two rear windows won't go up or down and only 3 doors work with the electric locks.
Old 09-08-2010, 01:27 PM
97western haulin 97western haulin is offline
97western haulin is starting off with a positive reputation.
Quote:
if its like mine its the switch. my driver side switch's would just stop working for a few hours or a day and then work just fine for two or three weeks then do it again. i finally replaced the switch and everything is good. if not then it could be the motor. if you dont know which it is i'd try switch's first cuz there cheaper.
installing doors with power windows on truck that had manual windows blazinjames Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 11 10-29-2016 01:31 AM
Windows and door locks Debdoodle 1997 - 2003 F150 2 04-12-2015 12:48 PM
1998 Ford F250 power windows Debdoodle 1999 to 2016 Super Duty 2 04-12-2015 12:41 PM
F250 Power window problem rioinaz 1999 to 2016 Super Duty 9 06-14-2010 08:27 PM
Door lock/window switch Problems kable Electrical Systems/Wiring 2 08-23-2004 10:44 PM
Tags
1997, auto, cab, crew, dont, driver, f250, ford, power, rear, stuck, truck, window, work, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
