Garrett powermax installed
Old 07-14-2011, 08:51 PM
tex25025's Avatar
tex25025
tex25025 is offline
The 64mm schwizer that I have has lower EGTs and cruising boost is around 5 psi. It's a great turbo.
  #32
Old 07-14-2011, 10:13 PM
AndeyHall's Avatar
AndeyHall
AndeyHall is offline
Originally Posted by Nice Work Truck
That it a good point have you checked you boots and Y-pipe for cracks?
No cracks or leaks in mine.
  #33
Old 07-14-2011, 10:51 PM
rdunagan's Avatar
rdunagan
rdunagan is offline
tex what did your turbo cost though?
  #34
Old 07-15-2011, 04:03 AM
tex25025's Avatar
tex25025
tex25025 is offline
1200 and about 2 hrs to install. Getting the old 03 turbo out and putting the new one in. Other then the pedestal it was a direct replacement.
  #35
Old 07-15-2011, 04:51 AM
Nice Work Truck's Avatar
Nice Work Truck
Nice Work Truck is offline
Originally Posted by rdunagan
thats what im afraid of is higher egts at cruising speed. i heard the psi is around like 5 though is that correct? and if you had to choose would you do it over again?
I would definitely do it again. It has been a great improvement.
  #36
Old 07-15-2011, 06:10 AM
2006powerstroke90's Avatar
2006powerstroke90
2006powerstroke90 is offline
When I did the turbo on an 03, I cant believe how easily it went in, the turbo basically fell into place.
No fighting with the up pipe or anything...
Glad you like your new turbo.
  #37
Old 07-15-2011, 09:33 AM
TexasA&M's Avatar
TexasA&M
TexasA&M is offline
Trying not to hijack the thread, but what is all this talk about getting the FICM tuned? What is the purpose?
  #38
Old 07-15-2011, 10:26 AM
rdunagan's Avatar
rdunagan
rdunagan is offline
where did you find it tex im interested in lookin at one
  #39
Old 07-15-2011, 11:10 AM
AndeyHall's Avatar
AndeyHall
Gives a little more power and is supposed to help fuel mileage some. Some people have seen up to 5mpg gain, I have noticed any but Bill says that was because my new PCM had a crappy strategy in it. Got my old computer in now but I haven't had a chance to run a full tank out yet. I do know it's getting better than with the newer PCM I had,
  #40
Old 07-15-2011, 05:12 PM
69cj's Avatar
69cj
69cj is offline
Originally Posted by npccpartsman
Some folks are just "lucky" I guess. I can't ever get the turbo to y-pipe flanges to line up right and seal off without loosening the y-pipe so I just do it by habit.
Have you had your batteries load tested, although it seems the FICM voltage would drop if you had one bad. Maybe not.
One more thing to try.......wait an extra few seconds after the glowplug light goes out to crank it and see it that makes a difference.
Tim, Has he checked his icp press? Could be a switch starting to get flakey.
  #41
Old 07-15-2011, 05:23 PM
TexasA&M's Avatar
TexasA&M
TexasA&M is offline
How is this different than running a tuner? Is this something that could be done in conjunction to an SCT? Do you have to send off your FICM to get it done?
  #42
Old 07-17-2011, 11:21 AM
AndeyHall's Avatar
AndeyHall
An SCT doesn't touch the FICM. Tuners only mess with the PCM/TCM. Power Hungry Performance is who did mine. You can do it one of 3 ways. You can go to a place that tunes them and have them do it in-house, or you can send your FICM in to them and let them tune it and ship it back, or you can "order" their little module for like $150 that they ship to you and you tune it and ship the module back to them. I think there's a deposit with that last option that you get back once they receive the module back though.
But here's pretty much the reason I did it...my truck being an 03, the original PCM strategy is the one that runs the best, however the cold starts are horrible. Cold starts are due to the strategy that's in the FICM. So Bill at PHP was able to give my FICM a tuned strategy with the inductive heating so that my cold starts are good, and my PCM the original strategy so that it runs like the original 03s did. Plus on top of that the FICM tuning gives a little extra power on top of that (about 20-30hp) and a little bit better fuel mileage (some people see it and some don't. i can't confirm either way, but i know for a fact that it at least won't hurt your fuel mileage).
gerry p
07-03-2013 09:31 AM
fishdaddymoe
New Member Introductions
06-12-2013 09:03 PM
AlexHunt
01-23-2013 03:34 PM
eman588G
09-07-2011 07:56 PM
kupaa
76
11-10-2010 02:32 PM
Quick Reply: Garrett powermax installed
