fuel cooler pump - Page 2 - Ford Truck Enthusiasts Forums
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
fuel cooler pump
Old 06-14-2011, 08:49 PM
cheezit's Avatar
cheezit cheezit is offline
cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.
you in dallas by chance? if so you may be local to me if you need more help.
Old 06-15-2011, 04:01 PM
scotiadallas scotiadallas is offline
scotiadallas is starting off with a positive reputation.
Like a charm.
Hi All,
I followed Cheezit's instructions today.
The fuel cooler rad was 2 X 10mm - easy to access and the rad came off easily. Like Cheezit suggested, I laid it down on it's side between the bumper and the charge air cooler. It slid down there perfectly.
I popped off the lid on the degas chamber and immediately started hearing a glug, glug, glug sound. I'm assuming that was the air and liquid moving around/settling.
I took of the fuel cooler hose and the glugging continued. I back filled at this hose but it only took about 100ml. After about 1 minute, the glugging sound subsided and everything was quiet. I filled the degas chamber and it took more than I expected. I filled it near the top, so I could see it through the sight glass window. I suspect that is too much but I noticed an overflow tube so I figure everything will work itself out.
I buttoned everything back up, started the truck and volia!, everything sounds good. I ran the truck for about 15 minutes and still everything was perfectly quiet.
I am packing the truck in the next hour to leave for Boston (7hr drive) so I'm hoping everything is good. I suspect that it is.
THANKS CHEEZIT! The time you took to post instructions saved me a good deal of money and stress. I had to take this trip and was worried I would be stranded roadside if that pump when while traveling.
I hope this post help others in the future.
If it starts squealing again I'll update this thread.
THANKS!
D
Old 06-15-2011, 04:02 PM
Ontario, Canada.
I'm in Ontario, from Nova Scotia but my name is Dallas.
All this = scotiadallas
D
Old 06-15-2011, 04:03 PM
senix's Avatar
senix senix is online now
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
Great outcome!
Old 06-15-2011, 06:32 PM
cheezit's Avatar
sweet very good to hear.
Old 06-16-2011, 10:28 AM
Quote:
In Boston now. It's purring like a kitten. Cheezit's fix worked.
Old 06-16-2011, 10:35 PM
StanleyZ's Avatar
StanleyZ StanleyZ is offline
StanleyZ is a splendid one to beholdStanleyZ is a splendid one to beholdStanleyZ is a splendid one to beholdStanleyZ is a splendid one to beholdStanleyZ is a splendid one to beholdStanleyZ is a splendid one to beholdStanleyZ is a splendid one to behold
Cheezit, you are the man. nice job.
Old 02-05-2014, 08:08 PM
jlshakes jlshakes is offline
jlshakes is starting off with a positive reputation.
Quote:
I just came upon this thread while trying to diagnose the squeal described above. Advice was spot on. Thanks for the help. Just joined up today. Hope i can be of help to someone else in future. One thing i add though, mine was pretty empty so i had to actually fill the main tube a little at a time and blow it through to get all the air out .once bubbles stopped, i put it back together and all good. Might even be able to do it without taking off cooler. Just pour in a little at a time and blow into tube to force bubbles out. Again thanks for info
Old 02-05-2014, 08:11 PM
Wow, glad to see my efforts in posting helped someone else. Cheezit is responsible, I'm just thanking him by posting and paying it forward - so are you!
Quote:
Old 02-05-2014, 09:06 PM
cheezit's Avatar
Always happy yo help
upgrading oil and egr cooler oughtsixbigred 6.0L Power Stroke Diesel 8 05-17-2015 05:58 PM
EGR Cooler Replacement Hellbringer 6.0L Power Stroke Diesel 20 10-24-2014 11:04 PM
list of gaskets and seals for oil cooler change? erikkloss 6.4L Power Stroke Diesel 1 08-13-2014 09:02 PM
Coolant flush with faulty EGR cooler? allingeneral 6.0L Power Stroke Diesel 29 03-10-2014 07:01 PM
95 7.3 won't run after replacing oil cooler Kevinfordfan97 1961 - 1966 F-100 & Larger F-Series Trucks 2 12-29-2013 01:39 PM
Tags
2008, 2010, 450, 64, coolant, cooler, cooling, diesal, diesel, f250, f350, ford, fuel, pump, reservoir, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
