replacing u joints in 4wd ? - Ford Truck Enthusiasts Forums
Old 09-06-2010, 10:34 AM
drunkenrich drunkenrich is offline
drunkenrich is starting off with a positive reputation.
Hey guys
I have a 1993 f250 351 4x4 and i think the u joints in the front are gone. When i put it in 4wd, if i go strait the front end makes minimal noise but when i turn it makes loud noises. I know its not the pumpkin or the driveshaft. I think it is the u joints by the wheels, the non greasable ones. How hard are these to replace? cost alot?
Old 09-06-2010, 10:48 AM
Kennewick's Avatar
Kennewick Kennewick is offline
Kennewick is starting off with a positive reputation.
Cost a lot to have someone else do it. I am going to do mine before snow falls and you will need the special hub wrench (spaner thingy) the rest is doable with patience and about 150ish. The axle ujoints are easier to take to a driveline shop for them to finish up and you reinstall. Others will be better at the description. If you need the front drive shaft ujoints done just take the whole thing with ujoints still attached to the driveline shop and have them spin it and press the joints on it too. Might look at new locking hubs if you need them also. I have heard that Spicer makes greasable ujoints for the axle ujoints but have not seen them.
Good go at it!
Old 09-06-2010, 11:35 AM
greg213187's Avatar
greg213187 greg213187 is offline
greg213187 is starting off with a positive reputation.
Spicer makes u joints I have seen them on broncograveyrd site they were pricy however. I got greasable u joints from federal mogul for $21 each. I never did u joints and just did mine the other day on both driver and passenger side. Use a socket that will rest on top of the u joint after removing the retaining clips and use a BFH to smack it through on each side. Don't make the mistake of hitting the receiving part of the axle shaft as I cracked mine but luckily had a donor truck to get a new one.
I also found PB blaster made them come out easier. If you search on you tube theres a bunch of videos showing how to do them. Hoe that helps.
Old 09-06-2010, 12:22 PM
Lazy K Lazy K is offline
Lazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to all
http://www.ford-trucks.com/forums/91...-u-joints.html Here is a great write-up if you want to do it yourself.
Old 09-06-2010, 04:37 PM
thanks guys
Need help from the noise/vibration detectives blanes 1987 - 1996 F150 & Larger F-Series Trucks 9 03-27-2016 06:26 AM
'03 Exp 4wd front CV joints play question stevebigos 1997-2006 Expedition & Navigator 1 11-17-2013 09:17 AM
Non replaceable U joints on front driveshaft? JoeDirt68 1999 to 2016 Super Duty 14 12-31-2010 06:44 AM
replacing u-joints slidingdelta Ranger & B-Series 5 06-26-2010 05:43 PM
REPLACING BALL JOINTs ON F150 2000 MODEL FASTSHIPPER4U 1997 - 2003 F150 11 01-09-2005 02:41 PM
Tags
1996, 99, cost, driveline, expedition, f350, federal, ford, joint, joints, mogul, ranger, rear, replacement, replacing, ujoints
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
