Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > 4 Cylinder Engines
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 09-05-2010, 05:04 PM
bozo4ford bozo4ford is offline
Garage is empty, add now
bozo4ford is starting off with a positive reputation.
Radiatior loosing H20 in 1986 Ranger truck
1986 Ford Ranger 2.3, 5-speed manual -
I would like to know if me filling up the radiator coolant before every time I drive somewhere, even locally, is a sign of a water pump going bad or a head gasket. it's a few inches to filler up to the top, but still.
True, I won't argue the fact that I also have bad valves, this being an old truck, but it seems to get me to where I want to go, but I would not feel so safe taking it out on the open highway for an extended road trip anytime soon.
What I have done was to check hoses from the radiator to the engine and noticed no leaks. is there anything else I could do without a major repair? I even used that stop leak a while ago, but that didn't help. Thanks for any help. bozo
  #2 (permalink)
Old 09-07-2010, 11:16 AM
TigerDan's Avatar
TigerDan TigerDan is offline
1968 Ford F-250
TigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputation
It's hard to try to guess something like that...it could be leaking from anywhere. What I would do is to rent a cooling system pressure tester and try to find the leak that way. It's a hand pump that attaches to the radiator filler neck in place of the radiator cap. You simply pump it up while watching the gauge on the unit to make sure you don't overpressurize the system, and at some point you should hear the hissing of the leak and that makes it quite easy to track down.
Click the image to open in full size.
If you build up to say, 15 PSI and the gauge holds steady, then there's no leak. If it slowly drops but you don't hear any hissing (or see coolant shooting out anywhere) then the next step would be to pull the spark plugs and listen at each cylinder using a length of hose held to each spark plug hole one at a time. Hissing from any one cylinder would indicate a blown head gasket or cracked head at that cylinder.
__________________
"alot" is not a word...
Political Correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end.
  #3 (permalink)
Old 09-08-2010, 12:08 AM
TigerDan,
It's a start. Thanks..I'm going to try to borrow one before I go out and buy a new one...thanks for your advice!
  #4 (permalink)
Old 09-08-2010, 01:37 AM
87 XLT 87 XLT is offline
87 XLT is gaining momentum as a positive member of FTE.
Autozone will loan you the gauge. Buy it use it bring it back for a refund.
Tags
1986, 20, 2003, cap, coolant, explorer, filler, ford, fuel, neck, pressure, psi, radiator, radiator evaporation, ranger, seal, tester, wisco
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
