Engine to Transmission plate
Old 08-18-2010, 08:58 PM
Justin's Green Truck's Avatar
Justin's Green Truck is offline
Hi, I am working on a Mazda b2300 with a 2.3l four cylinder and an automatic transmission. I am installing a new engine and have forgotten which way that thin plate between the engine and transmission goes. Could someone please help me out with this. There is a groove in the plate so I assume that it does matter. There is also ford and a part number stamped on one side. Which way does this go?
Old 08-19-2010, 07:10 AM
Bump. Help?
Old 08-19-2010, 11:29 AM
TigerDan's Avatar
TigerDan
TigerDan is offline
I believe it's asymmetric, so it should only fit one way. Here's a pic of the back of a 2.3 block, notice the bottom bolt on the right sits higher than the bottom bolt on the left. The block plate should be the same way:
Old 08-19-2010, 12:53 PM
That's exaclty what I needed to know. Thank you so much!
Old 08-19-2010, 01:52 PM
TigerDan's Avatar
TigerDan
TigerDan is offline
No problem...sorry I didn't see this till today.
BaronVonAutomatc
08-17-2015 06:51 PM
Wagonboy
12-30-2014 11:14 AM
dpaprocki
12-28-2014 11:59 AM
jomoflymo
07-14-2014 04:04 PM
wantoknowmore
01-05-2011 03:47 PM
Quick Reply: Engine to Transmission plate
