2.5L with fuel pressure problem
Old 09-08-2010, 12:47 PM
bolivartech's Avatar
bolivartech
bolivartech is offline
Question 2.5L with fuel pressure problem
I have a 2000 Ford Ranger with a 2.5L. I have been having trouble getting it to start so I started by replacing the fuel filter as it seemed like I was having trouble getting fuel to the motor at ignition. It runs just fine, only starting is the problem. I checked the pressure with the motor on, 65psi. With it off I could actually see the gauge drop from 65, relatively quick. Someone mentioned to me it could be the fuel pressure regulator or a check valve in the fuel pump. Does anyone know if those can be replaced individually, or if it could be something else?
77f2504by4
15
10-31-2021 03:07 PM
Penton97F150
1997 - 2003 F150
06-26-2016 10:49 PM
Benchwarmers6
06-08-2016 10:12 AM
Snowman69622001
02-08-2016 09:44 AM
westermaid
10-20-2015 10:08 AM
Quick Reply: 2.5L with fuel pressure problem
