need correct part name - Ford Truck Enthusiasts Forums
Old 09-05-2010, 03:43 PM
region2 region2 is offline
region2 is starting off with a positive reputation.
Have a 1986 Travelaire motorhome with a 460 in it that developed an exhaust leak on our previous holidays, lifted the doghouse and found the pipe running to each head is rotted,it is at the rear of the engine,has a check valve mounted to it,would anyone know the proper name for it?Thanks Vern
Old 09-05-2010, 04:48 PM
85e150six4mtod 85e150six4mtod is offline
85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation
Sounds like the EGR set up.
Stay tuned, you might get another post.
Something like so?
http://www.google.com/imgres?imgurl=...w=1276&bih=580
Old 09-05-2010, 05:05 PM
SOB Racing's Avatar
SOB Racing SOB Racing is offline
SOB Racing is starting off with a positive reputation.
From your post it sounds like your talking about a PCV valve. PCV valves usually vent gases out of the valve cover.
Old 09-05-2010, 06:15 PM
I should mention that this is a carburated 460,this pipe is separate from the egr baseplate and pcv hoses,It is part of the air emissions system,it has a "check valve" (I use to call them an antibackfire valve)mounted in the piping which is joined by a short hose to another vacumn operated valve which connects to the aircleaner.Am I helping?Thanks
Old 09-05-2010, 06:59 PM
ArdWrknTrk ArdWrknTrk is online now
pedant
ArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputation
Are you talking about the exhaust gas crossover at the back of the cylinder heads?
<a href="http://www.flickr.com/photos/24183730@N03/2341398064/" title="IMG_1903 by Jim_Urrata, on Flickr"><img src="http://farm3.static.flickr.com/2230/2341398064_eee3888e15.jpg" width="375" height="500" alt="IMG_1903" /></a>
This is like a Y pipe that comes up in front of the oil pressure sender???
Old 09-05-2010, 08:41 PM
pedant
GP-Sorensen 779-5372 Air Injection Reactor Pipe (crossover)
I found it on AutoZone's website under internal engine parts.
It's the first part listed (alphabetically)
Welcome to the forum region2!
I hope this helps!
Last edited by ArdWrknTrk; 09-06-2010 at 08:37 AM. Reason: link is broken, bad cookies...
Old 09-06-2010, 09:06 AM
Thanks ArdWrknTrk,that's it!!!!!thanks again everyone.
Old 12-10-2010, 07:58 PM
hotweekend hotweekend is offline
hotweekend is starting off with a positive reputation.
Question I having the same problem
I have a 93 Ford SD with a 460 (automatic trans) and I can't find the pipe going from the driver side manifold to the smog pump hose.
I just replaced the manifold and there is 2 pipes going out. One goes to the EGR valve and the other one goes across the motor (between the motor and the firewall) and plugs into a hose.
Do somebody have idea what I'm talking about ?
Old 12-10-2010, 10:20 PM
Bear 45/70's Avatar
Bear 45/70 Bear 45/70 is offline
Bear 45/70 has a good reputation on FTE.Bear 45/70 has a good reputation on FTE.Bear 45/70 has a good reputation on FTE.
Quote:
NO! PCV stands for Positive Crankcase Ventilation and sucks air through of the crankcase sucking out oil fumes, etc. Nothing to do with the exhaust. I agree with the EGR (Exhaust Gas Recirculation) or the air injection system. In either case I would look for a way to get rid of it but the EFI makes that difficult.
Old 12-20-2010, 07:15 PM
littlehusky's Avatar
littlehusky littlehusky is offline
littlehusky is starting off with a positive reputation.
Quote:
the OP has a carbureted deal.
Names willowbilly3 1947 and Older Ford Trucks 17 06-23-2016 08:03 PM
Why do you name your truck? Nicholas+ 1948 - 1956 F1, F100 & Larger F-Series Trucks 44 11-24-2015 10:52 AM
decal ideas Holiver31 The Next Generation 3 02-19-2009 02:37 AM
What did you name your truck? DvlRacer General Automotive Discussion 62 02-25-2006 06:08 PM
What's in a name? Nathan 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 2 04-11-2001 03:20 PM
Tags
460, 49, air, egr, exhaust, ford, gp, injection, leaks, pipe, reactor, sorensen, sorensenair, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
