frame cracked at steering box 77 f150 - Ford Truck Enthusiasts Forums
Old 09-05-2010, 10:42 AM
kelly77 kelly77 is offline
kelly77 is starting off with a positive reputation.
would like some info on repair kits available for cracked frames at front bolt on steering box
Old 09-05-2010, 01:38 PM
southernboy0122's Avatar
southernboy0122 southernboy0122 is offline
southernboy0122 is starting off with a positive reputation.
Mine is like that too. Im going to be stop drilling it to prevent it from cracking more. And far as repair kits, welding and prolly welding a thicker plate on top of it. I wonder if this is a common thing on these trucks?
Old 09-05-2010, 03:23 PM
c.l.nye's Avatar
c.l.nye c.l.nye is offline
c.l.nye is starting off with a positive reputation.
it is fairly common with big tires and abuse. What I did was use a second piece of frame from a donor truck and cut out a "patch" piece to go over the origional frame. I stop drilledthe cracks,"V"ed them and welded them up then ground downthe welds and fully welded the patch panel over it all. It worked for about 10 years before I changed frames because of rust.
Old 09-05-2010, 08:00 PM
78ford351m 78ford351m is offline
78ford351m is new and has a neutral reputation at this point.
Quote:
Change frames? I bet that was fun.
Old 09-05-2010, 09:39 PM
c.l.nye's Avatar
It was not all that bad. just labor intensive.
Old 09-05-2010, 11:46 PM
patsfan1 patsfan1 is offline
patsfan1 is starting off with a positive reputation.
i have a good long bed frame for sale a 100 bucks
Old 09-06-2010, 09:05 AM
Patsfan1, I Pmed you and your pms are off. Where are you located? Pics?
Old 09-06-2010, 10:50 PM
the frame i have is long bed its been painted with rustolem i am in lexington.
Old 09-06-2010, 11:01 PM
XzXPatrickXzX's Avatar
XzXPatrickXzX XzXPatrickXzX is offline
XzXPatrickXzX is starting off with a positive reputation.
Is it a 4x4 frame?
If 78FORD351M Isn't interested and its a 4x4 frame I am. I Live in southern Kentucky and would be willing to pick it up.
Old 09-06-2010, 11:06 PM
Quote:
Lexington ohio? I am in ohio.
Old 09-06-2010, 11:17 PM
gus11208's Avatar
gus11208 gus11208 is offline
gus11208 is starting off with a positive reputation.
If its a 4X4 frame the easiest fix is to weld a 1/4" plate onto the frame behind the stearing box. This is a common problem and if you replace the frame with another you might be haveing this problem again anyways. Just make a cardboard template to mark the shape and size of the plate and where the bolt holes for the power stearing box need to go. I just did mine last year. I had about $30 into it.
1991 4X4 Frame cracked at steering box redlightning 1987 - 1996 F150 & Larger F-Series Trucks 4 01-01-2014 02:24 PM
Cracked frame at steering box southernboy0122 1973 - 1979 F-100 & Larger F-Series Trucks 0 09-08-2010 05:31 PM
Frame Repair at Steering Box reynard101 1973 - 1979 F-100 & Larger F-Series Trucks 26 02-26-2010 08:01 PM
Frame cracking near steering box mwkobe 1987 - 1996 F150 & Larger F-Series Trucks 2 12-21-2003 06:36 PM
Frame crack prevention nickmobile67 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 14 10-28-2003 07:32 AM
Tags
4x4, 77, 78, box, cracked, f150, ford, frame, frames, kit, panel, patch, repair, sale, steering
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
