Show Me Your Nomenclature,I'll Show You Mine!
Interestingly, the 292/312 Y-block share the same bore spacing as the Windsor/Cleveland small blocks.
If the question was rhetorical, I apologize, but I hope this puts the issue to rest, once and for all.
Do you have any of the previous HiPo parts catalogs?
1969 was the first year for Motorsport. Hot Rod Magazine then published a similar soft cover "How To" inre to FE engines.
It was a FIASCO with casting numbers transposed as part numbers and vice versa. ID engineering numbers were transposed as casting and part numbers. Some part numbers were wrong due to typo'd mistakes.
Hot Rod got the info from two partsguys at Beverly Hills Ford...who insisted...UP FRONT...that they proof read the copy before it was published, but...
Hot Rod just went on ahead and published the info without it being proof read...and these mistakes have been copied over and over again by others ever since.
The former Hot Rod writer responsible for this FIASCO is now working at Edelbrock. I wonder how much of their info is correct?
Somewhere in my archives I have a reprint of an old HiPer parts catalog I think from '66. And I had an Off-Highway parts catalog until someone "borrowed" it. I wish I had more. I really get into old racing history, especially Ford stuff.
Recently I found in an antique shop a Rod and Custom magazine from January 1970 with an article telling how to put the "new" Boss 302 heads on the "351 raised deck Ford engine". The work was done by Valley Head Service in Tarzana, along with several local racers of the day they mentioned. Pretty fascinating how they engineered and milled spacer plates for the Boss intake to fit the wider intake space, and a custom modified distributor to fit, as well. It was quite the procedure that resulted in a bunch of intricate labor. And to think only a few months later, the Cleveland engine would have been introduced and created all this work useless. ;-)
The Hod Rod story incident isn't surprising. Sad, but not surprising.
Bore spacing is out the door as that indicate a small - medium - big blocks
Bore Space Cu in
4.38" 239 in³ Y-Block
4.38" 256 in³ Mercury
4.38" 272 in³ Y-Block
4.38" 292 in³ Y-Block
4.38" 312 in³ Y-Block
4.38" 221 in³ Windsor
4.38" 260 in³ Windsor
4.38" 289 in³ Windsor
4.38" 302 in³ Windsor
4.38" 351 in³ Windsor
4.38" 351 in³ Cleveland
4.38" 351 in³ Cleveland M
4.38" 400 in³ Cleveland M
4.63" 317 in³ Lincoln
4.63" 341 in³ Lincoln
4.63" 368 in³ Lincoln
4.63" 332 in³ FE
4.63" 352 in³ FE
4.63" 360 in³ FE
4.63" 390 in³ FE
4.63" 406 in³ FE
4.63" 410 in³ FE
4.63" 427 in³ FE
4.63" 428 in³ FE
4.63" 361 in³ FT
4.63" 391 in³ FT
4.90" 383 in³ MEL
4.90" 410 in³ MEL
4.90" 430 in³ MEL
4.90" 462 in³ MEL
4.90" 429 in³ 385-series
4.90" 460 in³ 385-series
Bore Space Cu in
4.63" 332 in³ FE
4.63" 352 in³ FE
4.63" 360 in³ FE
4.63" 390 in³ FE
4.63" 406 in³ FE
4.63" 410 in³ FE
4.63" 427 in³ FE
4.63" 428 in³ FE
4.63" 361 in³ FT
4.63" 391 in³ FT
4.90" 383 in³ MEL
4.90" 410 in³ MEL
4.90" 430 in³ MEL
4.90" 462 in³ MEL
uk-usa
estate = station wagon
petrol = gas
derv = diesel
loud peddle/throttle = gas peddle
fitter = semi truck mechanic
gearbox = transmission
spanner = wrench
and if you ever here an englishman say he is going to "smoke a ***" don't panic, he's not going to shoot a gay person, he is going to smoke a cigarette!!!, we call cigarettes **** for some reason
petrol = gas
derv = diesel
spanner = wrench
#28
#29
if you ever go to the uk you need to know about BOLLOCK, the word bollocks can be used in so many ways,
A Bollocking = telling off
bollocksed = dead/useless/bad
the bollocks = good
the dogs bollocks = really really good
bollocks = whatever/f you/up yours
grow a set of bollocks = grow some *****
bollocks = mans *****
**** = have sex
the bollocks = good
**** = have sex
#30
Are we beating about on our British Brethern? For What Use - They are our Brethern - Thay have Crumpets - lots of them - they destroy hundreds of thousands of crumpets a day - Those are hundred of thousands of crumpets that couldhave been headed our way.
Lets hear it for our British Bretheren - Hip hip horay - Hip hip horay -----Bloddy sods better keep it up ya know or there it will be all over the TV - Av you had your crumpets today?
