Liftgate won't open
I had a problem with my liftgate, about a year ago. You can hear the power door locks actuate, but when you pull on the tailgate handle, nothing happens, the tailgate will not open. There is a linkage between the handle and the release mechanism and it had become disconnected/broken. If you are able to get the tailgate open, then your task will be easier, you need to remove the interior panel of the tailgate to access the assembly.
Got to the problem....Need to know aprt #
I got the inside trim taken off, and I was able to manually move the switch to the unlocked position. I was bale to get gate open. I can't fing a replacement part for the actuator. Is Ford the only place I can get it? Does anyone have a part number for this part?
Thanks!!!!!
Thanks!!!!!
nysj83
1997-2006 Expedition & Navigator
02-27-2015 04:58 PM
Birdmayne
10-01-2014 10:32 PM
MacGyver60
07-17-2013 07:35 PM
2000F2504X4
08-03-2010 12:15 PM
