how to replace a brake line - Ford Truck Enthusiasts Forums
Maryland Chapter Join Chapter, Leader: jr32560
Old 11-21-2014, 02:52 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Brake Guides
Print Wikipost
Old 09-04-2010, 09:08 PM
dustybumpers's Avatar
dustybumpers dustybumpers is offline
Posting Legend
dustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputation
replaced the line over the rear on the 90 f 250 today, and thought Id take ya'll along for the ride.
find the leak
remove the line ends
open the clamps
set up the tools, measureing tape, magic marker, cutter, and flareing tool kit. remember that brake lines require a double flare
set the line you removede next to the new one
measure the 1st bend
make mark on new line
place center of bender on mark, and bend
continue this process untill all bends are made. the line is too long at this point, so measure, mark, and cut it with the tubing cutter. do not use a hack saw, it will leave a rough edge
set up the flaring tool, with the double flare adapter in it
remove the adapter, and flare it again
flare should look like this. if it has any rough edges, clean it up with some emery paper, make sure to blow off any dust
put line back on, use care to keep it straight when starting it, or you will cross thread the brass, and have to start over
tap the clamp lightly with screwdriver handle to lock in the line
hook up other end, and clean off all spilled brake fluid with brake clean
bleed the brakes, I use a clear tube into a clear jar, so you can see the bubbles.
check for leaks, if none, your all done. thanks go out to Bud & Jr for help in makeing this thread
Old 09-05-2010, 10:41 AM
BPofMD's Avatar
BPofMD BPofMD is offline
Posting Legend
BPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputation
Nice job, Charlie....that was easy! Nice to have that EASY button.
Old 09-05-2010, 12:12 PM
Posting Legend
Quote:
Originally Posted by BPofMD View Post
Nice to have that BUD button.
hahaha, fixed it for ya Bud
Old 09-05-2010, 05:41 PM
jr32560's Avatar
jr32560 jr32560 is offline
jr32560 is a splendid one to beholdjr32560 is a splendid one to beholdjr32560 is a splendid one to beholdjr32560 is a splendid one to beholdjr32560 is a splendid one to beholdjr32560 is a splendid one to beholdjr32560 is a splendid one to beholdjr32560 is a splendid one to behold
very well done Charlie
should help a few folks--I know many that won't attempt a hard line problem~~
Old 09-05-2010, 06:18 PM
Posting Legend
you one of them? bring er on up to the house, I'll fix er for ya!!!
Old 09-06-2010, 08:03 AM
66fdtrucknut 66fdtrucknut is offline
66fdtrucknut has a great reputation on FTE.66fdtrucknut has a great reputation on FTE.66fdtrucknut has a great reputation on FTE.66fdtrucknut has a great reputation on FTE.
Really like your tube bender, great info. should've seen the silly straw line I had to make for the subaru.
Charlie
Old 09-06-2010, 09:11 AM
tiny1's Avatar
tiny1 tiny1 is online now
NY CHAPTER LDR
tiny1 has a superb reputationtiny1 has a superb reputationtiny1 has a superb reputationtiny1 has a superb reputationtiny1 has a superb reputationtiny1 has a superb reputationtiny1 has a superb reputationtiny1 has a superb reputationtiny1 has a superb reputationtiny1 has a superb reputationtiny1 has a superb reputation
Great job Chalrlie and company.
Old 09-06-2010, 07:16 PM
Posting Legend
Quote:
Charlie
thanks, the bender is old, like me. hahahaha. did the lines on a 84 subaru 1 time. wow. tight little car, that one.
Quote:
thanks, mabe the powers that be can clean these threads up, and make a collection for people to view when they want to see how involved a project is
DIY head install/remove bracket. Lilpooh 6.0L Power Stroke Diesel 14 09-29-2015 06:53 PM
Oilburners IDI weekend Pics/Vids IDIDieselJohn Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 16 08-17-2015 04:42 PM
Reason why it's IMPORTANT to use only FORD/NAVISTAR Thermostat's in these engines! IDIDieselJohn Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 15 12-31-2011 04:16 AM
Nylon fuel line repair dustybumpers 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 17 08-24-2011 01:45 PM
My 1960 ford crew cab kashmcoll 1987 - 1996 F150 & Larger F-Series Trucks 10 12-23-2009 08:39 PM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
2002, 2007, 250, brake, f250, ford, lincoln, line, lines, mark, maryland, repair, replace, replacing, viii
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
