351 clevor puzzle
351 clevor puzzle
I could use some help,, I have recently picked up a 351W block with a bunch of parts to build a clevor. Almost everything that is needed, but it came with 2 cranks, one substantially larger than the other. Is there anyway to identify what I actually have?? The parts that I have been able to ID are a set of '75 clevland 2v heads, Ford Motorsports Clevor pistons 40 over and a set of exhaust spacer plates.....
It used to be that people sought out 400 cranks to stroke 351W engines. The main and rod journals are the same size between the two engines, but the counterweights needed to be trimmed and block clearanced to fit the longer stroke crank. Also the crank snout needed to be modified as I recall.
Then there was a horrendous amount of balancing required to make it all work.
Nowadays it's a lot more practical to buy a cast aftermarket stroker crankshaft. And curiously, I have one of those 400 cranks and a few sets of Cleveland 2V heads from way back hanging around gathering dust in the basement....
79_408_Clevor
12-31-2018 06:35 AM
kellar
19
11-05-2007 07:55 PM
