Wanna Help Solve a Mystery?
I have asked for help with my problem on another section of this forum. If you would like to read it and perhaps add your input I would very much appreciate it.
Thank you,
Jenny
https://www.ford-trucks.com/forums/9...ong-sorry.html
Disclaimer: I don't think it's engine related at this point.
Thank you,
Jenny
My son had a similar problem.....we changed tires and problem went away. Perhaps you have an unbalanced or bad tire.
When I swapped out my front end for a Dynatrac, my truck rode to the left; I had to add sleeves/collars to the top ball joints in order get the proper adjustment/alignment.
Hope you get to the bottom of your problem.
Lol! No way my grill is going to come out without a fight. That problem is on the back burner for now.
I am leaning more and more to the problem being the tires. Like I said in the other thread, I've had one just blow apart at the rim while parked. One totally peeled way while driving down the freeway. The one I had to buy as a replacement while out of town was warped and had 500 weights plastered to one side. So I expect that if I take that oddly weighted spare off and put it on the driver's side I will see a vast improvement.
I'm never buying Kumho (sp?) tires again. All this and they are less than six months old now.
Going to work now, have a great day and thank you for everything. I am so glad I found this forum!
Jenny
Jenny
Good Morning Jenny,
If you truelly believe it to be the tires, a simple rotation would be the quickest way to check.
I believe you are going to find the problem to be either a front u joint on one of the axle shafts, or a wheel bearing assembly. As some one noted on your other thread, The Tenn Chapter is real strong, and you may have a neighbor around that could take a look.
Good Luck!!
Sorry,, Welcome to FTE!!!
Good Luck!!
Good Morning Jenny,
Good Luck!!
Good Luck!!
My uneducated guess is that it would align most of the time. Occasionally while turning it would get a little outta whack and create that wobble and I would have to fight the steering wheel for a few miles until all felt OK again?
I'm taking that tire off when I finish with this job. I will try the crappy spare, the one that's malformed and see "if" it helps even slightly. If someone would like to give me some ideas of where to turn if the problems don't go away after that, I'd be very, very appreciative. The local Co-op dudes were super rude to me so I won't go back to the Athens Co-op for anything.
Someone around or in Athens, Tennessee?
Thank you for all of your kind welcomes and most certainly for everyones opinions and advice. I am keeping track of all of it and will try each thing in turn.
Jenny
Jenny
After reading the other thread and this one I would have to look towards the hubs. You should be able to lock and unlock the hubs with your hands without problems. If you have one binding up, it will cause additional drag on one side. if it is binding then it may also be causing the vibration you are feeling.
I would remove the locking hubs, (Can be done without even removing the wheel), and see how it does without the hubs in place. Should be able to tell with a short drive.
New hubs are easy and cheap to replace if that is the problem.
