Radiator moves to the other set of holes, battery tray changes between the two (but can still fit), and the water pumps on the V8 are the motor mounts, so the frame end stays the same. If the V8 comes from a car, the oil pan will be different, and might interfere with the tie rod. Other little things like linkages and wiring might too.
Look up inside the hood over the radiator . It has a seal on the bottom and a seal on top against the hood .The V-8 position is farther back than the I-6 where your air deflector should be now if present .
Thanks man...hopefully in a month or two we can start putting together the parts we need. I think the battery tray is on the passenger side with the V8 also, right?
Well the 52 is done and I have 3 extras for it anyway. I have a 48 f3 that has a flathead six that ate a ring in cylinder 1. The engine is shot anyway. None of the cyliners had good compression.
