5.4 Triton misfiring after complete tune up. - Ford Truck Enthusiasts Forums
Old 09-03-2010, 11:29 AM
mossberg500 mossberg500 is offline
mossberg500 is starting off with a positive reputation.
ok guys, bear with me. had my 2001 f150, 108k tuned up 3 weeks ago by former ford tech of 25 years. he replaced all coils, plugs, fuel & air filters, cleaned fuel rails, sensors. used all motorcraft parts. truck ran great for 3 days, then misfired bad. he as well as local dealer checked injector flow & compression, all ok. they have replaced #7 coil & plug and #7 injector twice over. PCM has been reset. still misfires. #7 usually seems to be the favorite. it's been on a WDS machine, found nothing. what's the next step??? anybody, somebody???????????
Old 09-03-2010, 08:33 PM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant future
Bad connection at the coil? Perhaps the plug is corroded causing a weak signal to the coil or there is a bad spot in the wire.
Old 09-04-2010, 09:55 AM
5.4 misfire after tune up
thnaks, i'll check. all plugs & coils are new, including boots. threw code for #1 cylinder yesterday, changed plug & coil again. trucks running great now but for how long don't know. it's like chasing a ghost.
Old 09-04-2010, 10:09 AM
02FX45.4 02FX45.4 is offline
02FX45.4 is starting off with a positive reputation.
Swap the coil and plug from #7 to a different cylinder. See if the problem travels with the coil and plug. If it does then move the coil to another and go from there. If it follows the coil then the coil is bad, if it doesn't the plug is bad, if it stays on #7 you may be taking the harness apart looking for a break or possibly a computer problem. I just tuned mine up and had a missfire on #1........I felt like a DA when I took the plug and coil out to find the gap of the plug was closed.
Old 09-04-2010, 02:09 PM
5.4 with misfire after tune up
tried the swap a few times. computer was reset by dealer. #7 cylinder has the 4th new coil & is ok. my personal ford mechanic changed coils all around twice. i'm wondering if motorcraft has or had a bad batch of coils they didn't pull. i'd like to talk to a rep about that. i pulled my boat with her today & she never missed a lick, i'm hoping the goat rodeo is over.
Need Help - 5.4 2V misfire jersey woods 1997 - 2003 F150 3 06-29-2015 10:11 PM
misfire 6 and 7 HAIRYLUGNUTS 1999 to 2016 Super Duty 11 10-27-2014 11:27 AM
01 4.6 Persistant #3 misfire. BioBurner 1997-2006 Expedition & Navigator 10 02-23-2011 10:38 PM
05 F150 misfire rich exhaust smell smotherss 2004 - 2008 F150 8 03-15-2010 09:48 AM
The Impossible 2001 Ford Taurus Problem!!! Peter94 General Automotive Discussion 15 09-25-2008 11:41 PM
Tags
54, 54l, bad, coils, complete, ford, misfire, misfiring, missfire, triton, truck, tsb, tune, v10, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
