2000 f150 5.4 Power Steering Pressure Hose - Ford Truck Enthusiasts Forums
Old 09-03-2010, 09:04 AM
kevhenn54 kevhenn54 is offline
kevhenn54 is starting off with a positive reputation.
2000 Ford F 150 Super Cab 5.4 L engine
My High Pressure Hose fitting on the Power Steering Pump shows signs of a "slight" leak. I am picking up the hose today. After reading some horror stories here and elsewhere I am asking myself; Should I replace the hose or wait for more signs of a failure. How difficult is the hose to replace? Any instructions? Pictures? Special advice? Special Tools?
Thanks for the Help
Kevin
Old 09-04-2010, 10:23 AM
chaser1602 chaser1602 is offline
chaser1602 is starting off with a positive reputation.
I got an old 18mm wrench and bent the open end over to a 90. Made it alot easier
Old 09-04-2010, 11:32 AM
I cannot get the 18mm nut off with the old hose connected and in tact. My thought is cut the steel line and use a socket to remove. The new hose is a 16mm fitting.
Old 09-04-2010, 12:37 PM
I got an old 18mm wrench and bent the open end over to a 90. then put a crescent wrench on the 18mm and took it off. Works all the time for me. You could cut it and use the socket to remove, but you still have to tighten the old line. If your new hose has a 16mm nut you might want to have another ride to the parts store because that dont sound right. I have never had that with the hoses I have replaced
Old 09-04-2010, 05:53 PM
Hose is replaced. You are correct the new hose is an 18mm also. Very tight job, took every bit of 2 hours to get off and 30 minutes to get new one on. I worked from the wheel well to loosen fitting on the gear then went below with a short 5/8 wrench and little by little got the fitting off. I then cut the steel line and forced a 11/16 deep 12pt socket on and the pump fitting came right off. A little un orthodox but it worked.
Getting the fitting started on the gear was tough, took 10 tries at least but it finally went. Thanks for the help.
Oh, I also found what was causing the leak. The white plastic washer was broke on the old fitting.
Old 01-16-2011, 09:11 PM
Fox Fader's Avatar
Fox Fader Fox Fader is offline
Fox Fader is starting off with a positive reputation.
I cut mine too. Used a hack-saw blade. Pretty quick here. I'd advise using a turkey baster to get most of the fluid out of the tank first. The new one was 11/16, used a crows foot to tighten it up. OE size was 18mm.
power steering hose pressure side leak phillycincykid 1999 to 2016 Super Duty 2 08-27-2013 09:12 PM
2003 5.4 coolant change khs2671 1997 - 2003 F150 6 04-05-2012 11:56 PM
1997 F350 4x4 7.3 turbo power steering hose part number PAGE2011 1994.5 - 1997 7.3L Power Stroke Diesel 3 03-14-2011 09:38 PM
2000 F150 rear brake hose bremen242 1997 - 2003 F150 6 04-13-2009 08:09 PM
Power steering pump for F-250 4x4, with 460 classyfish 1973 - 1979 F-100 & Larger F-Series Trucks 8 11-15-2002 03:34 PM
Tags
2000, 2003, 54, f150, f250, high, hose, line, power, pressure, pump, replace, replacing, seal, steering
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
