air conditioning
Old 09-01-2010, 12:32 PM
southern hunter56's Avatar
southern hunter56
southern hunter56 is offline
air conditioning
my a/c is not working, I was told there was blockage in one of the lines, they dont know exactly where. how hard is it to change seals and can I blow out the existing lines to clear them, is there a rebuild kit these people want to charge me $500.00 bucks to get it working the truck is a 1992 f150 it has already been changed over to r135 how much should this be costing me any help would be appreciated
Old 09-01-2010, 12:38 PM
F3fitty's Avatar
F3fitty
F3fitty is offline
Many times it is a clog in the orifice tube. I think mine has a clog in the same place. It blows cool air driving down the road but blows warm while stopped.
Old 09-02-2010, 02:07 AM
polarismuddman's Avatar
polarismuddman
polarismuddman is offline
x2 on the orifice tube. yes, the parts store sells an O-ring kit for the ac system and it shouldn't be a problem to blow hoses out as long as you're only blowing the hoses out..not the dryer etc. AC guys always charge alot.
Old 09-02-2010, 06:38 AM
lsrx101's Avatar
lsrx101
lsrx101 is offline
What leads "them" to believe there is a clog?
If there really is a blockage the debris had to come from somewhere, likely the compressor or a ruptured desiccant bag in the accumulator. Both are expensive fixes.
Without knowing the system pressures you are shooting in the dark.
F3fitty, your problem is not a blockage. Most likely your fan clutch is bad, you have the classic symptoms of a failed fan clutch.
Old 09-03-2010, 05:49 AM
TexasGuy001's Avatar
TexasGuy001
TexasGuy001 is offline
I agree, that sounds like a fan clutch issue your having F3fitty.
JOHN2001
15
11-14-2011 03:11 PM
78fordf150ranger
05-18-2011 07:32 PM
bluefishgary
02-11-2007 11:39 PM
broncoray
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
09-16-2004 02:34 AM
broncoray
21
12-12-2003 03:47 PM
Quick Reply: air conditioning
