she dont wanna run...
#31
IPR location ...
If you are going to pull the valve covers , run the motor & look for oil leaking up from the base of one of the injectors , may need to be warm too.. Also , watch the oil from the spill spouts , it should be an equal amount from each injector ...
Disregard the last pic...
#32
Hey, thanks so much for that pic - really easy to know now which is the ipr! Spoke to International again, and they said I could by it, install it, and then bring it back if it doesn't make any difference! Talk about service! Ford won't let me do that. So, this morning that's what I'm going to do. All the Chev guys here are wondering why I'm not driving my truck...
#33
Also wondering if this could be the cam position sensor? How do I test, and would this be a good one? Improved Blue CPS for 7.3L Ford Powerstroke Diesel
#34
The Blue CPS is for a different motor from International. It changes the timing. Some have reported they love it, others are concerned, especially if a chip is also used which will have another affect on timing.
#35
Hi Chris - now that you mention it, I remember reading the "tach-test" before. My tach works while cranking, white smoke while cranking, so that's not the issue. Sorry about that. I should have remembered (grace because I'm so new???). Well, I got an IPR from International today, and try to put it in tomorrow after my meetings, and see what happens. Have a great night. Michael.
#36
Heres a little help
97-15A 7.3L DI Turbo Workshop Manual
If you need info on the IPR click on the I
CPS click on the C ect...
And here is the IPR
Be careful not to damage it during dismantlement
http://www.dfuser.com/Install%20Guid...0Regulator.pdf
And here is the IPR
#38
Ok, so yesterday I changed the IPR who said removing the fuel bowl was easy??). The outer nut on the old one was loose, so that could have been a problem, but I decided to put the new one anyway. Got too dark to continue, so finished this am. Tried to start - started right away! Seemed to sound good too, so it definately made a difference (last time I could barely start her). BUT.....still belches out white smoke while revving in park. Oh, and while I was driving the battery light came on (??). I tested them while running and they were 14.55 (???)
#39
#40
Figured out the battery issue - I mangled a wire while under the hood doing the IPR. It's ok now. On the smoke issue, someone suggested head gasket, but the smoke smells like diesel fuel, and it only smokes while revving in park (no load). There is no smoke while driving and I give her the same amount of fuel.
#41
#42
If so your ICP is either shot or there is a short.
#44
Completely unburnt fuel comes out white and smells like diesel. That's why the truck smokes white for a few minutes after you pull the injectors and reinstall, there's a bunch of extra fuel pooled up.
Fuel that's been heated but is unburnt comes out black.
At least that's my understanding of it...
#45
Were on the same page, I thought your were suggesting that it was oil. But now that I reread I dont know why I thought that. ha o-well more coffee is required.
