Dash lights not working - Ford Truck Enthusiasts Forums
Old 09-02-2010, 03:38 PM
Dizz88's Avatar
Dizz88 Dizz88 is offline
Dizz88 is starting off with a positive reputation.
Exclamation Dash lights not working
hi everyone,
My problem is my dash lights arent working but my interior light is. Ive checked my fuses and they are all good, ive checked the actual switch and nothing seems to be wrong with it either. Does this sound like the light(s) behind the dash are burnt out? has anyone else had this problem?
Thanks
Old 09-02-2010, 07:54 PM
ArdWrknTrk ArdWrknTrk is offline
pedant
ArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputation
Do you have taillights?
Dash lights are on a separate circuit from the interior but with the taillights.
It could just be that the plug isn't locked into the back of the cluster.
Old 09-02-2010, 08:21 PM
danger-ranger93's Avatar
danger-ranger93 danger-ranger93 is offline
danger-ranger93 is starting off with a positive reputation.
my switch is messed up, so if i pull my **** all the way out my dash and parking lights wont work, i have to mess with mine for a while to get it all to work right... a switch is only 20 bucks i just gotta find time to order one
Old 09-02-2010, 11:01 PM
jplinville's Avatar
jplinville jplinville is offline
jplinville has a very good reputation on FTE.jplinville has a very good reputation on FTE.jplinville has a very good reputation on FTE.jplinville has a very good reputation on FTE.
Did you recently change the stereo? The instrument lights, I believe, are all on a common ground. If you check the switch, and it checks good, look for a short in the ground...AFTER you triple check the positive circuit.
Old 09-03-2010, 02:31 PM
Dizz88's Avatar
I checked the actual lights behind the dash and they seemed fine. Yes i do have tail lights. Nope i havent done anything to the stereo everything is completely stock.... Everything worked completely fine until one day the lights to illuminate my dash stopped working. Im thinking the only thing left to do is change out the whole headlight switch and hopefully this solves my problem.
Old 09-03-2010, 05:15 PM
pedant
Sometimes the plug connecting the switch melts and contact is lost.
Replacement plugs with pigtail wires are commonly available in the aftermarket.
I've posted the part numbers before.
The other thing that may happen is that the wirewound potentiometer (variable resistor) at the back of the switch can break, or the little spring metal ear that makes contact with it can break, bend, or otherwise come adrift.
I'd bet on the plug.
Let me see if I can dig up that post.
Old 09-03-2010, 08:33 PM
pedant
I'm assuming this is for your 1988 F-150, you didn't say...
Most autoparts should have it or can cross this number to another brand.
Pico 5311PT 1987-1993 Ford "F" Trucks Dash Headlight Switch Nine Lead Wiring Pigtail.
Hope this helps.
Old 09-05-2010, 03:55 PM
Dizz88's Avatar
yeah it is for my 88. I havent had time to look at it again but tomorrow i will be taking my dash apart again. So what your saying is that the plug is probably no good anymore? Thanks for the help
Old 09-05-2010, 06:52 PM
pedant
In many cases the heat from the dimmer and corrosion of the contacts melts the plug or makes the old plastic very brittle.
That's why they sell a replacement plug.
As I said, the switch could be bad in the back. But you will be able to tell when you pull it out.
Since you have had the dash apart before it would be worth checking that the other end of the harness is firmly seated in the back of the cluster.
Old 09-06-2010, 02:26 PM
Dizz88's Avatar
The plug itself looks fine and nothing seems to be wrong with it. Im going to go to a scrap yard and try and get the whole switch and plug together sometime this week. Hopefully this will solve my problem
Old 09-06-2010, 02:45 PM
pedant
The brown wire is variable current for the dash lights.
Can you check for current coming out of the switch when it's turned right up to the stop?
Maybe you can trace it and look for an open or short?
Old 09-07-2010, 05:01 PM
jlr1073's Avatar
jlr1073 jlr1073 is offline
jlr1073 is starting off with a positive reputation.
I am having the exact same problem with my '91 F250... I believe my problem started one day when I was turning on my headlights via the switch and I heard a tiny "pop" noise followed by a tiny metallic sound as if something like a washer had popped off and fell off the backside of the switch. My headlights still work but no interior/dash lights now. My guess is that I/we need a new switch. Good luck!
Old 09-07-2010, 07:32 PM
kennethrasnake's Avatar
kennethrasnake kennethrasnake is offline
kennethrasnake is starting off with a positive reputation.
mine done this and it was my dimmer/interior light switch. All i had to do is replace it and everything worked wonderfully.
Old 09-08-2010, 08:23 AM
Dizz88's Avatar
I got a a new switch unit. unpluged my old one and put the new one in and problem was solved. Looking at my old one i can tell that the spring was broken. Thanks for the help guys
Old 05-02-2013, 09:59 PM
Robert Jax Maxwell Robert Jax Maxwell is offline
Robert Jax Maxwell is starting off with a positive reputation.
my dash lights on my 97 ford explorer are out
wht do i do to fix could it be a fuse
no parking lights,tail lights,dash lights jerrysrios Electrical Systems/Wiring 20 01-09-2017 04:58 PM
No Dash Lights, No Power to Fuse Box? (Tail Lights OK) DesertZuki 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 7 05-15-2015 11:03 PM
Headlights wont turn off dennis112 1997-2006 Expedition & Navigator 8 12-11-2014 01:30 PM
Dash lights not working Zachthemoo2 1973 - 1979 F-100 & Larger F-Series Trucks 8 09-18-2014 11:34 PM
Dash lights CPorter 6.0L Power Stroke Diesel 0 06-05-2013 09:27 PM
Tags
1979, 1987, 1996, 99, cluster, dash, explorer, f150, f250, ford, instrement, lights, tail, troubleshooting, truck, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
