no turn signals or brake lights at trailer plug
Old 09-02-2010, 01:48 PM
Rocksetter's Avatar
Rocksetter
Rocksetter is offline
Went and bought a trailer last night and no right turn signal, after trying three different trailers the same problem. Took one home and when I got home no brake or turn signals just running lights.Should have stated 2002 ranger 4.0, Test light shows no power to the plug except running lights. Checked all the fuses listed in the owners manual and the relay could I be missing something?
Old 09-02-2010, 07:03 PM
87 XLT's Avatar
87 XLT
87 XLT is offline
I dont have wiring diagrams for an 02, but most Fords use a trailer tow right turn & stop relay, and a trailer tow left turn & stop relay. Theres also a seperate fuse for these relays.
Have you checked these relays and the fuse???
BTW, i've been told that Ford does not always install these relays & fuse on the assembly line, so they might never have been installed on yours.
Old 09-02-2010, 09:13 PM
Rocksetter's Avatar
Rocksetter
Thank you for the reply. The prob was at the 4 pin plug. Michigan crud ran up the wires.
Old 09-03-2010, 10:21 AM
87 XLT's Avatar
87 XLT
87 XLT is offline
Thanks for the update, i'm glad you got it squared away.
No1Hookman
2017+ Super Duty
112
02-28-2020 08:53 AM
sjn951
1999 to 2016 Super Duty
02-16-2017 11:45 AM
RUSTANG67
2009 - 2014 F150
07-18-2015 07:25 PM
adamsrancho
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
18
04-26-2014 11:06 AM
BlueE-150
08-18-2008 11:41 PM
Quick Reply: no turn signals or brake lights at trailer plug
