Headliner
Sometimes they are salvagable. Just depends on how bad it is. I'm not sure what to use to repair it but I would definitely give it a shot before getting a new one. If the spot is big enough, you may have to peel away the liner from the spot to the edge and apply adhesive this way so that you dont end up with two small sags. Kind of a roll it to the edge so there are no air bubbles kind of thing. Just my .02 Cents.
Hope this helps buddy.
I had mine redone at a upholstery shop. Came out OK but the place I went to must have changed hands. I'm not real pleased with it but its OK. A big headliner like yours if this shop did it would probably be $500.00 conservatively. If you did the R&R.
I've seen pins (best description) at auto parts store that hold up the material so it doesn't get worse. Or so they say.
Finding a reputable shop is the hard part. I don't like to let anyone I don't know/trust do ANYTHING to my truck, even if its just gluing the fabric back to the foam on my headliner
AGREED. Ever since I started working on vehicles for myself, there are very few people I trust with it! I would just try to get it looking half way normal for now until you REALLY need a new liner, then put one in.
Not trying to hijack your post, but can you guys check my new post out too? I need advice and I'm thinking about doing this today:
PAINT MY TOOLBOX ? - Ford Truck Enthusiasts Forums
Chase , pull the liner & remove the fabric, scrape off the glue . I got replacement material , & adhesive from a local shop for $30.00. reg cab . you can do it yourself if you wish ..
