Block Weight
Old 02-18-2003, 06:20 AM
stryder's Avatar
stryder
stryder is offline
Question Block Weight
Can someone tell me about how much a bare block weighs? I'mm looking at having a 4-bolt block sent to me by freight, and was wanting to see how much it will cost.
Thanks,
Stryder
Old 02-18-2003, 07:42 AM
f100dw's Avatar
f100dw
f100dw is offline
Block Weight
I think it's a little less than 300 lbs. I'm not sure, though. It's been a while since I seen it the spec on it. Dave
Old 02-18-2003, 07:53 AM
georgedavila's Avatar
georgedavila
georgedavila is offline
Block Weight
With caps, pallet and packaging, figure 275lbs. Find a direct shipper and get quotes on terminal to terminal where it's dropped off at a terminal and picked up at a terminal. Otherwise, the cartage fees will run close to $200 alone and more if you have it picked up from/delivered to a residence.
Old 02-18-2003, 08:46 AM
stryder's Avatar
stryder
stryder is offline
Block Weight
OOOUUUUUUUCCCCCHH! $180!! I guess its all about how bad you want something. I'd still call it a good buy for $480 with shipping.
Thanks,
Stryder
Old 02-21-2003, 08:30 PM
Frankenstang57's Avatar
Frankenstang57
Frankenstang57 is offline
Smile Block Weight
I'm with you there! It cost me $73 to ship a T-5 from Colorado to Virginia. you can look at the bright side though, at least it's not complete 700#+ version!
