1995 f150 stalling & bucking - Ford Truck Enthusiasts Forums
Old 09-01-2010, 09:01 PM
fenwick fenwick is offline
fenwick is starting off with a positive reputation.
I have a 95 F 150 with a 302 5 spd. When you come to a stop it will shut off, and when you are going down the road the truck will start bucking. It doesnt do this all the time. I have changed spark plugs, cap, rotor, wires, fuel filter,map sensor, tps sensor, egr valve, clean throttle body, and the idle air control.
Old 09-01-2010, 09:42 PM
timbersteel's Avatar
timbersteel timbersteel is online now
timbersteel has a good reputation on FTE.timbersteel has a good reputation on FTE.
Welcome to FTE!
Looks like you have really thrown some money into this problem. Has the CEL come on at any time? If so, have you pulled the codes? Could be the TFI. It's located on the drivers side near cowl. It could be going bad. It could also be that the TFI is overheating. Check for a good grounds. also check the screws(fasterners) to the TFI for corrosion.
I'm a newbe too. Hopefully some other veteran FTE folks will chime in later with some other suggestions.
Keep us Posted!
EDIT*** Here's a link to a Post here on FTE concerning the Driver-Side Fender-Wall mounted TFI
http://www.ford-trucks.com/forums/37...fi-module.html
Last edited by timbersteel; 09-01-2010 at 10:54 PM. Reason: Found Post Concerning TFI Module
Old 07-05-2013, 07:36 PM
IdaSpaceman IdaSpaceman is offline
IdaSpaceman is starting off with a positive reputation.
...there are at least three different threads on this very issue and zero end with an answer. So here I sit--having the same issue...changing the same parts and ending up with no positive results. ugh
Old 07-05-2013, 09:15 PM
Welcome to FTE.
Could you elaborate on the problem you have. Is it exactly as stated by the OP? Have you pulled codes? Let us know all problems, repairs, and troubleshooting you have performed, and we'll try our best to help you out.
Also, is this on the same vehicle as the OP listed, 95, 302, standard trans? Mileage?
Old 07-08-2013, 07:07 PM
Quote:
Originally Posted by timbersteel View Post
Welcome to FTE.
Truck began bucking at 40-42 MPH, then the problem disappeared for a few days. A week later it had trouble at idle and I was able to "gas it" into the local garage.
I assumed (bad on me) that it was simply a fuel filter or pump problem. To date they have changed out the air and fuel filter. They have cleaned the EGR valve, throttle control, injectors, and replaced the MAF sensor.
They were about to declare victory...but as I was about to drive away--it stalled. I am waiting for a call-back and will ask about the codes. At this point I am going to recommend they check the ignition coil and idle control valve. Initially they assumed it was a vacuum leak.
1995 F-150, it has a Jasper remanufactured engine replaced at 188,000. It is currently parked at 202,000. I recently purchased the vehicle and so I have no further history. It's a .302 automatic with two tanks--only the front one is operable and I just had it replaced due to rust.
I will be sure to post again should the local garage be able to diagnosis and repair.
Thanks for asking.
Old 07-08-2013, 07:25 PM
jdan1993150 jdan1993150 is offline
jdan1993150 is starting off with a positive reputation.
Not sure if the fix applies to the 302 or if the 4.9 was the only engine with the EGR issue, but there are a few threads with a write up about how to create an EGR valve restrictor plate with sheet aluminum and two EGR gaskets. Might be something to look into, if the EGR is flowing too much at cruise it can cause stumbling or "bucking" at highway speeds.
As for the intermittent stalling and other issues, I would suggest opening your ECM cases and checking for capacitor leakage, it's a very common issue and before you drive yourself crazy it's a simple enough thing to check off the list. And if they are leaking, then you've found at least one issue.
Old 07-09-2013, 09:35 AM
Will pass it along...and yes, I am familiar with the EGR Valve solution...always perplexes me why the folks just wouldn't replace the valve itself vice manipulation?
Old 07-09-2013, 05:22 PM
**Update**
shop alleges the dirstributer cap was the issue. They have logged 50 miles on the vehicle and claim no issues. We shall see...I am absolutely NOT confident after reading the various threads on this site. Many of which changed out the dirstributer cap very early on. I wagering on having to replace the ICV, coil springs, and the ECM before it is over. Finally--service writer had no knowledge of thrown codes and the wrench was gone for the day. More to come...regardless.
Old 07-14-2013, 07:00 PM
**Update 2**
Approx another 50 miles...issue has not reappeared. At this point--I am guarded, however optimistic. Fingers crossed.
Old 12-24-2013, 01:09 PM
94f15093 94f15093 is offline
94f15093 is starting off with a positive reputation.
I have a 94 f150 5.0 4x4 auto 4sp has 151k. got it and was running great and I replaced plugs and wires and here I crossed over 2 wires and it was bucking and missfireing like crazy so I put them on currently and it still dose the same thing so I replaced. EGR valve tps sensor plugs wires cap rotor ICM module coil pack cleaned ICV and fuel filter adjusted timming to 10. still bucks carries on start up fast idels good. when warmed up it start up expecially going up hills when it gos into over drive it gets really bad I have no idea what it could be any help or suggestions will be appreciated. Thanks
Old 12-24-2013, 02:30 PM
best of luck-- we are over 1000 miles since our issue...has not returned, thankfully.
Old 12-24-2013, 06:40 PM
joey2fords's Avatar
joey2fords joey2fords is offline
joey2fords is gaining momentum as a positive member of FTE.joey2fords is gaining momentum as a positive member of FTE.
since the problem started right after you changed plugs and wires i would go back and triple-check my work ( i know you said that you corrected 2 crossed wires, but the problem is still there). check that you have the firing order right and the direction of rotation right. check that the plugs are snug and the wires are snugly seated on the plugs and on the cap. check that the cap and rotor are properly installed.
it would be a good idea to run your engine in a dark place and check to see if there is any cross-firing going on between the plug wires.
if you still have a problem after this then check for codes.
Old 12-24-2013, 06:59 PM
I took it to get codes checked but the engine light wasnt on and the garage said its not reading anything showing its running perfect. Well I just went out and checkes for spark and cylinder 5 spark plug is sparrking bright blue all around it and sparking from the sides of the coil could it be a bad plug?
Old 12-25-2013, 10:23 AM
joey2fords's Avatar
you can check that easily by swapping plugs, but i would suspect the wire ... not seated properly or the connector not connecting with the plug.
Old 12-25-2013, 11:41 AM
since the problem started right after you changed plugs and wires i would go back and triple-check my work ( i know you said that you corrected 2 crossed wires, but the problem is still there). check that you have the firing order right and the direction of rotation right. checked that the plugs are snug and the wires are snugly seated on the plugs and on the cap. check that the cap and rotor are properly installed.
Ok I put a new wire on stoped the sparking around it and checked plugs they r good but it still keeps bucking and missfireing a little less but still constant could it be a faulty coil pack?
Engine bucking and missing over 35 mph pnp522 1987 - 1996 F150 & Larger F-Series Trucks 0 08-10-2015 12:28 PM
****1994 Ford F150 Bucking and Jerking*** Eric Shaw 1987 - 1996 F150 & Larger F-Series Trucks 4 07-28-2013 09:54 PM
87 ford 302 efi has no power fordpower65 1987 - 1996 F150 & Larger F-Series Trucks 5 03-29-2011 07:15 PM
94 460 EFI missing and bucking Boss300 1987 - 1996 F150 & Larger F-Series Trucks 3 09-05-2010 09:17 PM
01 F150 4.2L buck/jerking nmband13 1997 - 2003 F150 3 02-23-2010 06:07 PM
Tags
150, 1992, 1995, bucking, f150, f15o, ford, stalling
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
