1995 f150 stalling & bucking - Page 2 - Ford Truck Enthusiasts Forums
Old 12-25-2013, 07:39 PM
Truckin Bob Truckin Bob is offline
Truckin Bob is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by jdan1993150 View Post
As for the intermittent stalling and other issues, I would suggest opening your ECM cases and checking for capacitor leakage, it's a very common issue and before you drive yourself crazy it's a simple enough thing to check off the list. And if they are leaking, then you've found at least one issue.
Yep, jdan nailed it.
Here's a link that describes the leaking capacitor problem and symptoms :
Click here: A9x ECM's (and same years ECM's) Failures Due to Age
This is becoming a VERY common problem.
Bob
Old 12-28-2013, 10:54 AM
94f15093 94f15093 is offline
94f15093 is starting off with a positive reputation.
Bob
Ok where is the ecm located in the truck? And I replaced the plug wires with good ones and new coil and same thing.
Old 01-01-2014, 11:46 AM
Ok found the ECM module and I took it out opened it up and there is no burn marks corrosion nothing super clean. Any ideas? Thanks
Old 08-19-2014, 05:23 PM
Jeffs E150 Jeffs E150 is offline
Jeffs E150 is starting off with a positive reputation.
1995 E150 5.8L Stumbles & Bucks (Fixed)
I have a 1995 Ford E-150 5.8L with an E4OD transmission. I had an issue where the engine would buck and stumble and would periodically spark knock when driving 40 to 50 MPH around 1400 to 1800 RPM part throttle. I spent 3 weeks troubleshooting the issue. The engine had to be at operating temperature and running in “closed loop”.
This condition never set any DTC’s, which I checked for frequently with a scan tool. The engine acted like it was quickly being shut off and back on, it did not act like a cylinder or coil was misfiring. I also ran the KOEO and KOER tests with the scan tool and everything worked correctly. Being that the distributor cap & rotor, spark plugs and fuel filter were due for a replacement I installed new parts but none of those parts eliminated or even improved the bucking and stumbling.
Although I have had a factory service manual since the van was new, I did not have the diagnostic manual which I needed to have to check all the other engine components. Luckily I found a 1995 factory diagnostic manual on eBay for $30.
Using the Ford diagnostic manual I checked the operation of the MAP, TPS, ECT Sensor, IAT Sensor, EGR Valve, EGR Position Sensor, EGR Vacuum Solenoid, O2 Sensor and they were all functioning correctly. I also checked the timing, fuel pressure, and I did a coil load test and plug wire load test and they were all OK. I also drove the vehicle in “open loop” mode numerous times to see if the condition occurred which it did not. I was able to put the engine into “open loop” various ways: removed SPOUT; disconnected ECT sensor; disconnected O2 sensor.
Since the other components checked out as good I next focused on the Engine Control Module. I removed the ECM and removed the cover to look for any anomalies. I found a very small area of corrosion on the circuit board that was only visible with a magnifying glass. Being that all the other components were working correctly I then suspected the ECM as the cause of the issue.
I ordered a Remanufactured Cardone ECM at AdvanceAutoParts.com for $72 after using coupon code TRT30 and received it in two days. Right before I swapped out the ECM I drove the van just to make sure the engine still bucked and stumbled which it did. Once the new ECM was installed I drove the van and the issue was gone. I have driven the van about 150 miles with the new ECM and it is still driving good.
95 F-150 4.9L missing/bucking while cruising raynist Ford Inline Six, 200, 250, 4.9L / 300 191 05-12-2016 03:51 PM
Engine bucking and missing over 35 mph pnp522 1987 - 1996 F150 & Larger F-Series Trucks 0 08-10-2015 01:28 PM
87 ford 302 efi has no power fordpower65 1987 - 1996 F150 & Larger F-Series Trucks 5 03-29-2011 08:15 PM
01 F150 4.2L buck/jerking nmband13 1997 - 2003 F150 3 02-23-2010 07:07 PM
Bucking and jumping delgan 1987 - 1996 F150 & Larger F-Series Trucks 25 12-30-2003 09:04 AM
Tags
150, 1992, 1995, bucking, f150, f15o, ford, stalling
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
