Squeaky Tailgate - Ford Truck Enthusiasts Forums
Squeaky Tailgate
Old 09-01-2010, 06:20 PM
rvx290 rvx290 is offline
rvx290 is starting off with a positive reputation.
Squeaky Tailgate
drivin me nuts, the latch on the LH side of my tailgate started squeaking when I drive over bumps, simple fix I thought, a litte spray lube, problem solved... for 2 days, then started again, so I sprayed more, soaked it down good, same thing again couple days later does anyone have this problem or know what might be the problem, if there is something I might need to adjust etc?
Old 11-23-2011, 12:44 PM
Paraspolo Paraspolo is offline
Paraspolo is starting off with a positive reputation.
Quote:
Long story short, try this...
Open tailgate 45 degrees and slide it away from the squeak(should move .5-1 inch). Close tailgate. Check squeak.
The long version
I have a 02 sport trac. I bought it new in 02. I have had this problem for most of the life of my truck. I have lubed all the moving parts and joints only for it to come back. It wasn't until last week that I may have solved my problem. I always thought that my problem was in the latches. I could have sworn the sound was coming from that area. My gf likes to sit on my tailgate and smoke after leaving places, shopping, eating, visiting, which kinda pissed me off cause when I would close the tailgate just right it wouldn't squeak for a little while. Then she would open it and that position was now gone and back were the squeaks. I started hearing the squeaks not in the latches but in the hinges at the base of the tailgate. I pulled loose the tailgate to investigate, didn't see anything out of the ordinary. I put it back on. Still heard the squeak. Then I did something, something that seamed to fix my problem. With the gate open and about 45 degrees I pushed it to the side. It slid about half an inch to an inch. I was trying to see if I could see anything in the hinge. I couldn't, so I closed the tailgate without sliding it back. No squeak. I was in shock. I opened it up and pushed it back. Squeak. Opened it up and pushed it away from the squeak again, no squeak. THANK YOU JESUS! I hated that squeak so much. I love driving with all my windows down, including the sliding rear. But that squeak pissed me off so much I couldn't take it and would close my window. My girlfriend always said just ignore it. But I couldn't. It angered me so much. It was like it was stabbing my brain every single bump. I hope this helps. Let me know
Old 11-23-2011, 05:13 PM
tbear853's Avatar
tbear853 tbear853 is offline
tbear853 has a very good reputation on FTE.tbear853 has a very good reputation on FTE.tbear853 has a very good reputation on FTE.
remove the TG and line the hinge hole a tad bit of grease followed by a couple layers of dryer sheet and reinstall, trim excess ...
... the sheets will also help hold in the grease in the future.
Works for trailer hitch ball lube too, even without the grease added for a mess free hook / unhook experience.
Old 06-22-2016, 09:10 PM
gpops's Avatar
gpops gpops is offline
gpops is gaining momentum as a positive member of FTE.
The tailgate is too loose. I just fixed mine this evening:
  1. Remove inner tailgate cover (8 Torx screws)
  2. Un-clip the two green clips in the handle mechanism holding the connecting bars
  3. Pull the bars up out of the clip and move them over ~1/4" so they're tighter. The threads on the bars match up with threads in the clip to lock in place.
  4. Close the tailgate and test. Adjust the bars until the sound is gone and the tailgate stays shut.
While you have the tailgate cover off, lube all moving parts. Don't forget to pop the two black clips out (picture of one side below) and lube them so your handle doesn't squeak. Also lube the tailgate lift support (shown in picture below).
Can The 2 Remote Tail Gate Releases Be Disabled wharrell 2017 Super Duty 31 02-11-2017 09:35 PM
The Tailgate benwalt 2015+ F150 3 12-03-2016 02:02 AM
'08 f250 tailgate won't latch RancherJV 1999 to 2016 Super Duty 2 09-25-2016 08:32 PM
New tailgate prep hivoltj 1978 - 1996 Big Bronco 3 02-14-2016 09:11 PM
Fixed my hard-to-open tailgate LSCRX 1987 - 1996 F150 & Larger F-Series Trucks 1 01-19-2016 08:10 PM
Tags
2004, 2008, escape, explorer, f150, f250, fix, ford, gate, repairing, squeaking, squeaky, sqwecky, tail, tailgate, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
