Remote Key Fob Programming
Hello all,
Just swapped the 08 Limited for an 08 Limited EL! The EL only came with 1 aftermarket remote start fob. I still have one OEM fob from the other truck and am wondering how to program it for the new one. I know how to do this on GM vehicles, but not on the Ford. Any help is greatly appreciated!
I love playing with new toys also and I dont consider that wasting my time I just got my Gold system alarm/remote start installed last saturday so this is also a new toy for me.
The three pictures above are the bronze/silver/gold system fobs. I bought the gold and the third fob is what I have.
Hi all.
I also have had an issue where the Expy didn't come with fobs.
It's a 2007 Expedition EL Limited with the power liftgate. We bought the 5-button remotes figuring it just *had* to have the fob-operated liftgate.
I go through the programming procedure fine and all of the buttons operate correctly (door lock/unlock, panic, lift gate glass) *except* the power lift gate. Is there an additional procedure to get the power lift gate working, or is there possibly a fuse or other option that wasn't installed to enable this? The lift gate *does* work with the rear handle as well as the button on the dash.
TIA!
SickPup404
TIA!
SickPup404
Gold key fob
Hey fellas, I just figured out where to find my keyless entry keypad code for my Expy on this forum, now a question about my key fob.
I have the gold version according to the pics above. I downloaded the PDF instructions for programming it and after a few reads I kind of figured it out except one thing. Where is the override button at?????
My remotes will lock and unlock doors and though I haven't tried it yet, I believe the panic button works. What isn't working is the blue remote start button and the "1" and "2" buttons which I believe are for the memory seats.
Any help would be greatly appreciated.
Thanks, Jason
Thanks, Jason
SickPup…..I know this is an old post, but did you ever figure out what the problem was? I have the exact same issue with my 07 Navi, liftgate fob button does not work, otherwise all other buttons works as designed. I bought a new key fob and still the liftgate button does not work. Button on the dash and the pull handle works fine.
Sorry, no help. I don't recall ever getting the liftgate button to work on the aftermarket fob.
We traded the Expedition on a 2011 Edge, so my memory is getting a bit fuzzy about it, but I remember two things that stuck with me because I couldn't solve them - the liftgate button on the key fob, and I never could find the factory door code sticker on the ECU in the passenger side foot well...
Best of luck!!
Best of luck!!
